jhasbrouck(at)woh.rr.com Guest
Posted: Sun Oct 29, 2006 8:30 am Post subject: Tunnel damage from rudder cable |
A while back there was a posting regarding damage to the tunnel side wall from the rudder cables where they attach to the rudder pedals. I don't remember a resolution to this issue. I'm at the point of mounting the rudder pedals to the airframe and wondered if the problem was due to using the more forward of the mounting points for the rudder bearing blocks. Since the tunnel tapers as you move aft I surmise the more aft mounting point for the rudder blocks would give more clearance. Was this a one time problem? Those flying, what position did you use for the rudder pedals? I'm 6' 3" and guess that I'd like as much room for my legs as possible.
John
#40264
Tim(at)MyRV10.com Guest
Posted: Sun Oct 29, 2006 9:52 am Post subject: Tunnel damage from rudder cable |
I'm almost 6'2", and used the forward mounting of the pedals, which
works well. I'm sure the aft mounting would work for me too, but I'd
have to take up more rear-seat room by moving my seat back a couple
inches. My wife would probably prefer the aft mounting, as she's more
like 5'2", and can't reach the pedals well without scooting up in
her seat about 6". I have thought about remounting mine if I could
do it easy enough, just to try it for her. I may try to just add
some blocks to her pedals though.
As for the cable rubbing, my cables are pretty close, but they don't
rub, so it's working out for me.
John Hasbrouck wrote:
| Quote: | A while back there was a posting regarding damage to the tunnel side
John
#40264
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sun Oct 29, 2006 10:45 pm Post subject: Tunnel damage from rudder cable |
When I was putting the rudder pedals in I checked fore and aft positions and noticed the inside rudder cable bolts hit the tunnel when I had the tunnel cover removed. As soon as the cover was installed there was no contact.
Steve
40205
flysrv10(at)gmail.com Guest
Posted: Mon Oct 30, 2006 3:30 am Post subject: Tunnel damage from rudder cable |
This was a condition that I experienced. I am not sure why my passenger pedal rubbed against the tunnel skin (left rudder). I have since shorten the hanging rod and used spacers in the blocks to move the pedal to the right. I am using the rear most mounting holes for the pedals which would create the most space between the pedal and the tunnel.
I saw this condition developing during construction but ignored it thinking that, since everything else fit so well, this will would work it's way as I installed the tunnel cover.
So, my recommendation is to trial-fit the pedals before you rivet the front cover.
Rob Kermanj
On Oct 29, 2006, at 11:29 AM, John Hasbrouck wrote:
| Quote: | A while back there was a posting regarding damage to the tunnel side wall from the rudder cables where they attach to the rudder pedals. I don't remember a resolution to this issue. I'm at the point of mounting the rudder pedals to the airframe and wondered if the problem was due to using the more forward of the mounting points for the rudder bearing blocks. Since the tunnel tapers as you move aft I surmise the more aft mounting point for the rudder blocks would give more clearance. Was this a one time problem? Those flying, what position did you use for the rudder pedals? I'm 6' 3" and guess that I'd like as much room for my legs as possible.
John
#40264
AV8ORJWC
Posted: Mon Oct 30, 2006 9:34 am Post subject: Tunnel damage from rudder cable |
Randy (#006) got a ding on his DAR inspection for the connection of the rudder pedal cables to pedal attachment. It was in regards to bolt, nut and cotter pin orientation. The DAR was concerned that footwear would disengage the attachment over time.
One of my 200+ changes was to weld a horizontal tab off each inboard vertical pedal mount (cutting away the factory vertical attachment)and scribe an arced cut-out into the tunnel sidewalls. The objective was to keep the cables straight inside of the tunnel. Connection was from within the tunnel, eliminating the connecting hardware on the outside sidewalls of the tunnel. Every bend and every inch of tubing increases the resistance to the cable movement.
John
#40600
From: owner-rv10-list-server(at)matronics.com on behalf of John Hasbrouck
Sent: Sun 10/29/2006 8:29 AM
To: RV LIST
Subject: Tunnel damage from rudder cable
John
#40264
toaster73(at)earthlink.ne Guest
Posted: Tue Oct 31, 2006 5:44 pm Post subject: Tunnel damage from rudder cable |
Someone made this mod already I saw it on some website can't recall. Was it
Dominici?
-Chris
#40072
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Tue Oct 31, 2006 7:02 pm Post subject: Re: Tunnel damage from rudder cable |
| toaster73(at)earthlink.ne wrote: | Someone made this mod already I saw it on some website can't recall. Was it
Dominici?
-Chris
#40072
A friend and I went up to John Nys this weekend and I took these shots of a 10 he is working on in his shop. I think this is the type mod you are describing.
gary
45.66 KB |
496 Time(s) |
56.45 KB |
480 Time(s) |
wcurtis(at)core.com Guest
Posted: Wed Nov 01, 2006 10:18 am Post subject: Tunnel damage from rudder cable |
This is a great idea! Now you gonna make me take my installed rudder pedals apart so I can do this mod. >A friend and I went up to John Nys this weekend and I took >these shots of a 10 he is working on in his shop. I think > this is the type mod you are describing. >gary > >Attachments: >http://forums.matronics.com//files/pict1320s_450.jpg >http://forums.matronics.com//files/pict1316s_174.jpg William Curtis http://nerv10.com/ [quote][b]
wvu(at)ameritel.net Guest
Posted: Wed Nov 01, 2006 10:34 pm Post subject: Tunnel damage from rudder cable |
Are those AN3's? Do you know if John did his studies to ensure they can withstand the forces on the pedals?
Anh
#141
orchidman
Posted: Thu Nov 02, 2006 10:05 am Post subject: Tunnel damage from rudder cable |
I noticed that his rudder pedals had a horizontal tab at the cable attach point. My cables do not have this. Did John add these to allow for possible deflection? >Didn't ask. I would think that a 3 would be an absolute >minimum. I am also a little concerned about the design >of the tab flexing in a max petal deflection. > >But that is all about experimental building. The concept >is there, now the next improvement [Question] > >> Are those AN3's? Do you know if John did his studies to >> ensure they can withstand the forces on the pedals? >> Anh >> #141 >>>http://forums.matronics.com//files/pict1320s_450.jpg >>>http://forums.matronics.com//files/pict1316s_174.jpg William 40237 - Fuse/Finish http://wcurtis.nerv10.com/ [quote][b]
