Posted: Mon Oct 30, 2006 9:44 am Post subject: Drilling B-Nuts |
Fellow listers,
Any hints on an easy way to drill the B-Nuts to comply with Vans fuel pickup bulletin?
Ralph Capen
Bruce(at)glasair.org Guest
Posted: Mon Oct 30, 2006 10:15 am Post subject: Drilling B-Nuts |
I have a jig that allows me to drill across a corner tip any nut.
Bruce
www.glasair.org
Posted: Mon Oct 30, 2006 10:28 am Post subject: Drilling B-Nuts |
More info on the jig please.....
Where did you get it......?
Any pictures...?
Ralph
Ed Anderson
Posted: Mon Oct 30, 2006 11:02 am Post subject: Drilling B-Nuts |
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
dfischer(at)iserv.net Guest
Posted: Mon Oct 30, 2006 11:25 am Post subject: Drilling B-Nuts |
I cross-drilled without the jig (though I've bought one since). The soft
aluminum makes it pretty easy. Just dimple the nut with your center
punch, start the drill at an angle (so it doesn't slip) and rotate it as
you drill to the correct angle to cross-drill the corner.
Doug Fischer
RV-9A Wings
Bruce
www.glasair.org
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Tue Oct 31, 2006 7:15 am Post subject: Drilling B-Nuts |
Thanks Rick!
jpleasants(at)bellsouth.n Guest
Posted: Tue Oct 31, 2006 7:49 am Post subject: Drilling B-Nuts |
I did it freehand, also. 1/16 inch bits are cheap, and I broke at least
one.
Jim
