One Good Answer Can Save an Entire Afternoon...
Site Admin
PostPosted: Sun Nov 08, 2026 4:02 pm    Post subject: One Good Answer Can Save an Entire Afternoon... Reply with quote
Dear Listers,
First, a sincere thank you to everyone who has already made a Contribution to this year's Matronics List Fund Raiser. I appreciate your support!
One good answer can save an entire afternoon in the shop.
It might be a wiring explanation that finally makes sense. A part number you've been trying to track down. Or a tip from someone who already made the mistake you were about to make?and took the time to write about it.
Sometimes that answer comes from a conversation happening today. Sometimes it's waiting in the archives, in a message somebody wrote twenty years ago. Either way, it can make a real difference when you're trying to figure out what to do next.
Once the problem is solved and the project is moving again, it's easy to get on with the work. That's exactly what the Lists are here for. This November Fund Raiser helps keep that everyday usefulness available throughout the year.
Even if you mostly read along or quietly search the archives, I hope the Lists have made your project a little easier and more enjoyable. A Contribution is a simple way to help keep that resource available whenever you need it.
I'll keep doing the work behind the scenes. Your Contributions help cover the cost of keeping the Lists and archives running, accessible, and free of advertising.
If Matronics has helped you solve a problem, avoid an expense, or enjoy your time in the shop, please consider making a Contribution today. Whatever amount works for you is appreciated.
You can contribute here:
https://matronics.com/contribution
Or mail a personal check to:
Matronics / Matt Dralle
148 Skyhawk Drive
Toledo, WA 98591
If you've already contributed this year, thank you again for your support!
Thanks for helping keep all those good answers available for the next person who needs them.
Matronics Email List and Forum Administrator
RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot
trevord
PostPosted: Sun Nov 15, 2026 5:53 pm    Post subject: One Good Answer Can Save an Entire Afternoon... Reply with quote
Hello there,
I am trying to change my email address to booking(at)waihekelodge.co.nz as I will no longer being using the trevord(at)orcon.net.nz email going forward.
Can you change it for me please ?
When I update it, it ignores the change.
Trevor
 Filesize:  208.02 KB
 Viewed:  50 Time(s)
Trevor
