Anyone had a gps antenna go inop?
wdaniell.longport(at)gmai
PostPosted: Sat Jul 19, 2025 9:02 pm    Post subject: Anyone had a gps antenna go inop? Reply with quote
Mine is a dynon...the gps went offline in the middle of a flight.   Wiring looks good although i havent tested it yet.
System says "gps offline"...
Im hoping its the antenna....would be an easy fix
William Daniell
LONGPORT
+1 786 878 0246
DuaneFamly
PostPosted: Sat Jul 19, 2025 10:23 pm    Post subject: Anyone had a gps antenna go inop? Reply with quote
If you have another antenna I would first turn the unit on with the old antenna still attached. Then if it still says offline, then leave it on and swap out the antenna. If it comes right up then you have found the problem. Do you have a replacement antenna? I might have a replacement. When I ordered a replacement antenna for the Garmin 296 I use as a backup, they charged me for one antenna but sent me one "box". It contained a dozen antennas. They have a BNC connector on the end. Are you in FL or NJ?
Mike Duane
Chandler, AZ
Europa XS Conventional Gear
On Saturday, July 19, 2025 at 10:02:39 PM MST, William Daniell <wdaniell.longport(at)gmail.com> wrote:
William Daniell
LONGPORT
+1 786 878 0246
Mike Duane
