Area-51
Posted: Fri Jul 11, 2025 1:53 am Post subject: Brake Caliper Blocks |
Does anyone have a Cleveland part number for replacement brake blocks on the Mono?
RogerJMills
Posted: Fri Jul 11, 2025 3:19 am Post subject: Brake Caliper Blocks |
If you mean the brake pads, I have the following info about a Rapco
alternative which I picked up from this forum some time ago. I haven't used
it personally so can't vouch for it, but it might be worth a try:
RA066-10600 Brake Lining
Replaces: Cleveland PN. 066-10600, Old PN. 66-106, 066-0200, 66-2, 066-0300,
66-3, 66-56, 66-57 & Piper PN. 752-308, 752-309
Best Regards
Roger Mills
_________________ Roger Mills |
Area-51
Posted: Fri Jul 11, 2025 11:11 pm Post subject: Re: Brake Caliper Blocksngs |
Thanks Roger,
That number cross references with Parker Cleveland 066-10600 Linings (x4), 105-00200 are the rivets (x6)... 6" External System, Caliper 30-18
Am familiar with Rapco , thanks for direction 👍
Area-51
Posted: Sat Jul 19, 2025 3:17 am Post subject: Re: Brake Caliper Blocks |
Job done 👍
Description: |
Filesize: |
144.83 KB |
Viewed: |
2265 Time(s) |
Description: |
Filesize: |
91.12 KB |
Viewed: |
2265 Time(s) |
h&jeuropa
Posted: Sun Jul 20, 2025 7:34 am Post subject: Re: Brake Caliper Blocks |
Rapco pads work well and we are now using Matco pads. They are a little less aggressive material.
You photos look like the head of the rivet is on the plate. Most instructions call for the head to be on the pad so there is more area touching the pad itself. Small point for future reference. We've done them both ways!
Jim Butcher
RogerJMills
Posted: Sun Jul 20, 2025 8:11 am Post subject: Brake Caliper Blocks |
Just a slight worry: when the head of the rivet is on the pad, as designed, there will be a more evenly distributed load on the pad. This might be an issue because the pad material is brittle and it may be subject to higher stress if the rivet head is on the plate.
Hopefully there will be a high enough safety factor for it not to matter?
It may be worth keeping a close eye on how the pads are wearing because the pad life will be shorter and the rivetted end will gouge the disk sooner and more than the flat head would.
Roger Mills
Sent from my mobile
Jim Butcher
http://forums.matronics.com/viewtopic.php?p=515472#515472
Area-51
Posted: Mon Jul 21, 2025 2:20 am Post subject: Re: Brake Caliper Blocks |
Thanks for the info guys; yes fitted Cleveland Parker friction blocks... I put the new rivets as the old ones were fitted, and points noted. The catalogue shows rivet orientation as you mention. Might get another set of rivets and redo them. It's not a big job to R&R.
Area-51
Posted: Wed Jul 30, 2025 3:02 am Post subject: Re: Brake Caliper Blocks |
Now they are correct; the Cleveland Parker catalogue is difficult to see orientation but does show it correctly. The rivets for the removable section need to be slightly longer reach.
Description: |
Filesize: |
136.11 KB |
Viewed: |
2042 Time(s) |
