Eric Page
Posted: Thu May 29, 2025 1:15 pm Post subject: Project Prototype Clear-Out |
I have several prototypes for recent projects on my bench that are excess to requirements. I'm offering them to anyone who wants one. Prices reflect my cost for circuit boards and components (no labor). Shipping will be via USPS Ground Advantage (cost calculated by eBay). First come, first served.
To make this manageable and easy for everyone, each item is listed on eBay by Item #, as indicated below. To discourage random buyers from taking them, there are cryptic titles and no descriptions or photos on the eBay listings. Just click the link and purchase the Item # that matches the item you want. If the eBay link is dead, the item is sold out.
NOTES:
1. These are experimental prototypes, not commercially produced products. I'm a hobbyist, not an electrical engineer. I designed, built and tested these items to the best of my ability, but I cannot and do not guarantee that their operation will satisfy your particular needs.
2. Before you install one of the overvoltage protection modules (OVM-14 Mk III -or- OVP Relay Driver), please read all warnings in the documentation carefully.
3. If you have any questions, please ask before purchasing. No returns. Tech support is limited to the documentation posted on this forum and my ability to answer questions here.
4. Shipping may not be immediate, as I won't be visiting the post office every day. Please expect some delay before shipment. The eBay listings indicate three business days; it may take longer.
Thank you!
Here's what I have available:
ITEM #1 ($16.15 ea):
2 available. OVM-14 Mk III Crowbar Overvoltage Protection modules. Assembled and tested. Includes two 1/4" Molex Avikrimp (equivalent to PIDG) quick-connect crimp terminals and a piece of heat shrink to cover the module.
Project Details:
http://forum.matronics.com/viewtopic.php?t=16782170
(Scroll down to Mon Apr 7th, 2025, 6:32 pm)
eBay Link:
https://www.ebay.com/itm/267268597270
ITEM #2 ($15.90 ea):
1 available. Elevator Trim Left Stick Priority modules. Assembled and tested. Includes the mating D-Sub connector, 10 stamped-and-formed D-Sub pins (9 required) and two backshells (one for the module and one for the mating connector).
Project Details:
http://forum.matronics.com/viewtopic.php?t=16783500
eBay Link:
https://www.ebay.com/itm/267268600647
ITEM #3 (SOLD):
0 available. Overvoltage Protection Relay Driver. Assembled and tested. Includes a flanged enclosure box with wire exit grommet. Does not include PUSH ISOLATE switch. Board has 12" wires (M22759/16-22) attached.
Project Details:
http://forum.matronics.com/viewtopic.php?t=16783524
ITEM #4 ($10.55 ea):
4 available. Overvoltage Protection Relay Driver. Assembled and tested circuit board ONLY. Does not include the enclosure box, grommet or PUSH ISOLATE switch. No attached wires.
Project Details:
eBay Link:
https://www.ebay.com/itm/267268610155
ITEM #5 ($23.30 ea):
2 available. Landing & Taxi Light Wig-Wag Controller. These modules will alternately double-flash LED lights drawing up to 5A each. You can see this module in action in this video clip (watch the hangar door in front of the airplane; the landing lights -- off-road "pod lights" on my friend's Kitfox -- are being flashed by this module for about 10 seconds):
https://www.youtube.com/watch?v=tvhDvCLLxiA&t=859s
These are tiny, double-sided surface-mount boards, so I have assembled and tested them. There's a very small potentiometer on the board to adjust flash rate; you'll need a jeweler's screwdriver. Each module includes a mating connector, 10 stamped-and-formed D-Sub pins (9 required), and two backshells (one for the module and one for the mating connector).
Schematic and wiring diagram:
https://drive.google.com/file/d/1-s-isKgwcrDoLQtIFXlp65q8sZe43n8E/view?usp=sharing
eBay Link:
https://www.ebay.com/itm/267268615278
ITEM #6 (SOLD):
0 available. Low Voltage Warning Module (based on Mr. Nuckolls' AEC 9005-110-1). Assembled and tested. Flashes an LED (included) when the monitored bus goes below 13V.
Project Details:
http://forums.matronics.com/viewtopic.php?t=16783530
ITEM #7 (Free!):
1 available. Low Voltage Warning Module bare circuit board ONLY (no components installed or included).
Project Details:
If you want one of these, send me an email or a private message (go to the Project Details link and click the "PM" button at the bottom of the first post). Include your name and mailing address (U.S. and Canada only, please). I'll edit this post to indicate when these boards are gone.
