VM1000 AMP/Current circuit
garyvanremortel(at)gmail.
PostPosted: Mon May 12, 2025 2:50 pm    Post subject: VM1000 AMP/Current circuit Reply with quote
Not sure if many of you are still flying with the original Lance Turk designed VM1000, but my ammeter circuit was periodically dropping out and I was unable to get advice on the old girl.
I made myself a breakout cable to monitor the signals/voltages on the sensor lines during flight.  The 10VDC was dropping out, so I took the DPU apart and traced the supply path to VR2 on the analog PCB.  I reasoned that since this 10VDC only powered the ammeter circuit, it must be flakey.  I replaced it (TI 78L10AC) and now all is well.
-GV
recapen(at)earthlink.net
PostPosted: Mon May 12, 2025 3:27 pm    Post subject: VM1000 AMP/Current circuit Reply with quote
Good job Gary!
I parted out my VM1000 years ago and replaced it with an AFS 3400 when i had issues with mine.
Sent using myEarthLink
-GV
