JohnFrance
Joined: 17 Sep 2014 Posts: 83 Location: Grenoble France
Posted: Fri Mar 21, 2025 12:01 am Post subject: Europa-List Digest: 1 Msgs - 03/18/25 |
Hi Ron,
That’s a good point, the set-up dimensions for a new block are given in the manual (from memory 79mm) but no wear limit. From the dimension you gave you are a good way below that.
I have a 700-6-6 Air Trac tyre fitted and with a new block there is nearly 1” between the top of the tyre and the fuselage. That reduces over time as the block ages. The current block is now about 8 years old and there is still about 3/8” of daylight between tyre and fuselage.
If you want to get a better feel for the situation you could lift the tail to put the aircraft in the flying attitude and then measure the ground clearance between the propeller/ground.
| Quote: | On 19 Mar 2025, at 07:33, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 25-03-18&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 25-03-18&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Tue 03/18/25: 1
Today's Message Index:
1. 11:23 AM - Mono Rubber block height (rparigoris)
________________________________ Message 1 _____________________________________
Time: 11:23:00 AM PST US
Subject: Mono Rubber block height
Hi Group
What is the acceptable distance between the upper and lower compression plates
for the black rubber shock absorber before replacement is necessary sitting on
main gear with wings on?
I have a XS Mono with 914.
Mine looks a little bulgy at 2.3"
Thx.
Ron P.
_________________ Europa mono Nr 192 |
