Pushing a Europa uphill
rparigoris
PostPosted: Sun Mar 16, 2025 4:17 pm    Post subject: Pushing a Europa uphill Reply with quote
Hi Group
We are going to bring our XS Mono Fuse over to my home this week.
We will set up at the base of my driveway and put on a custom Dolly. The base of my driveway is relatively level.
Then we need to get it up the driveway: without wings or stabs. The drive is about a 7.5-to-8-degree angle.
Questions:
** Can 2 guys push a Europa fuse up such a slope? 914 is installed.
** Can you push backwards on the stab spar, 1 guy on each side?
Thx.
Ron P.
SPURPURA
PostPosted: Mon Mar 17, 2025 4:57 am    Post subject: Re: Pushing a Europa uphill Reply with quote
That’s a pretty steep grade. Might be safer to use the winch that is on the trailer. I wouldn’t recommend pushing on the stab spar.
N951EU - Tri-gear & 912ULS, N77EU- Mono & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY.
SPURPURA
PostPosted: Mon Mar 31, 2025 3:02 am    Post subject: Re: Pushing a Europa uphill Reply with quote
rparigoris
PostPosted: Mon Mar 31, 2025 6:14 pm    Post subject: Re: Pushing a Europa uphill Reply with quote
Hi Group
We had a winch on hand but wasn't necessary to get fuse into garage.
Two guys with some huffing and puffing could have done it, one pulling on tailwheel spring with a rope and one pushing on door frame, but if it got away from us it could be ugly fast.
We had a third guy and push was a non-issue.
If I ever have to do it with just 2 guys, will use winch.
Ron P.
