Oil and water hoses
JonathanMilbank
PostPosted: Fri Jan 03, 2025 9:09 am    Post subject: Oil and water hoses Reply with quote
Several years ago I bought a set of silicone hoses from someone in Sweden who created shaped coolant hoses for the Europa and also provided silicone hoses with protective lining for the oil system. He no longer makes or provides these items. Someone, but I can't remember who, stated that these hoses would last at least twice as long as the rubber types and I have no reason to doubt that.
However my engine is currently off the aircraft, so a fellow pilot who has a minor share of the aircraft would like the oil hoses to be replaced by rubber originals, even though the silicone looks and feels supple, as good as new! I would prefer to continue with silicone, because the recommendation is to replace ALL rubber items every 5 years. The oil hoses are the difficult ones to access, particularly the return line from the crankcase. But I must also consider my friend's opinion.
So two questions, pertaining only to the oil hoses. What's the problem with continuing to use lined silicone hoses for the oil? What specification do you recommend for the rubber oil hoses, which I hope to purchase from a local automotive parts supplier?
Burrilla
PostPosted: Sat Jan 04, 2025 4:34 am    Post subject: Oil and water hoses Reply with quote
Not aware of anyone who has used silicone for oil hoses. Lots of people have silicone water hoses, including me, and life certainly better than 5 years in my experience. I also have silicone hose for the fuel filler and carb to air box which are fuel resistant.
I would start by looking at the ROTAX documents for hose specification, especially looking at pressure range, heat and oil, hydrocarbon, protection.
I have seen a silicone water hose damaged by external heat from exhaust.
A good source of info is the motorsport suppliers like
Samco silicone Hoses, Kits, Clip Kits, Classic & Xtreme at Merlin Motorsport
merlinmotorsport.co.uk
[img]cid:C26ADA10-5A35-4410-A88D-A865C287E575[/img]
Silicone hoses have developed well but not sure about oil on an engine side or the fuel lines either.
If you are UK also you could consult the LAA on their thoughts.
Good luck.
Alan Burrill
On 3 Jan 2025, at 17:10, JonathanMilbank <jdmilbank(at)yahoo.co.uk> wrote:
--> Europa-List message posted by: "JonathanMilbank" <jdmilbank(at)yahoo.co.uk>
http://forums.matronics.com/viewtopic.php?p=515189#515189
<==========================bsp; - The Europa-List Email Forum -
 Filesize:  29.22 KB
 Viewed:  11085 Time(s)
Duncan McFadyean
PostPosted: Sun Jan 05, 2025 2:00 am    Post subject: Oil and water hoses Reply with quote
<<....What's the problem with continuing to use lined silicone hoses for the oil? ...>>
One reason would be that the polyester reinforcement used in normal silicone hoses will let go at the temperatures that can be seen by the oil (in the return especially and feed too before the oil cooler).
It is possible to get silicone hose with Nomex as the reinforcement fibre; I've used these successfully in place of the 1" cylinder head water hoses on the bottom of the engine.
Duncan McF
Good luck.
Alan Burrill
 Filesize:  29.22 KB
 Viewed:  11053 Time(s)
