Rotax 912ULS oil consumption
christoph.both(at)acadiau
PostPosted: Wed Nov 13, 2024 9:35 am    Post subject: Rotax 912ULS oil consumption Reply with quote
Hello Europa Group,
I am reaching out to see if a group member has available, as a spare part, the right front side header exhaust tube assembly (Cylinder #1)?
A few days back, I discovered that it sheared right through at the mounting clamp, after I smelled some exhaust fumes. Glad I checked right away. The entire assembly, though, still held the broken exhaust pipe perfectly in position, preventing most of the hot gases hitting the nearby classic right radiator. Lucky.
Now I try to get lucky finding someone who might have this part and willing to part with it. I am also considering buying the entire double silencer exhaust if in new, not yet installed condition.
Any leads? Suggestions? Repairable? Weldable?
Thank you very much,
Christoph Both
Europa Classic #223
Wolfville, Nova Scotia, Canada
 Filesize:  2.35 MB
 Viewed:  6332 Time(s)
