Z101b with Shunts, Shunts as Fuse Link Junctions
werner schneider
PostPosted: Fri Aug 30, 2024 12:14 pm    Post subject: Z101b with Shunts, Shunts as Fuse Link Junctions Reply with quote
Joe,
The Dynon does work as well with Hall effect sensors however they do not
sell them (I did source the GRT once) for it.
Werner
On 12.03.2022 01:47, user9253 wrote:
An ammeter is optional. As long as the voltage is above 13.5, you will know that the alternator is working. The pilot does not need to know how many amps the alternator is putting out. It is useful to know current for troubleshooting purposes. Save troubleshooting for when safely on the ground using a handheld meter. If desired to know amps while airborne, install a shunt on the standby alternator to help manage loads. There is no need to know amps while the primary alternator is working.
What kind of EFIS are you going to install? If none, have you considered a GRT EIS Engine Monitor? I believe it works with a HALL effect sensor.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=506293#506293
