JL2A
Posted: Wed Apr 10, 2024 8:08 pm Post subject: Tight Gear Handle |
Just replaced a very stiff flap handle that eventually started leaking, and now flap handle is fine but the gear handle is very hard to move!
This is only with air pressure applied. When there is no air pressure, the handles move easily.
Could there be air leaking back through the system and pushing on the wrong side of the selector disc inside the handle?
markbitterlich(at)embarqm Guest
Posted: Thu Apr 11, 2024 2:29 am Post subject: Tight Gear Handle |
For Yak models, air from the "other side" of the gear actuator vents through the landing gear selector valve itself, so if there was air leakage through an actuator to the other side, you'd hear a hiss at your landing gear selector all the time the master air valve was turned on.
Could be the valve itself. Ask Dennis Savarese.
Mark
-------- Original message --------
From: JL2A <info(at)flyingwarbirds.com.au.matronics.org>
Date: 4/11/24 12:12 AM (GMT-05:00)
To: yak-list(at)matronics.com
Subject: Yak-List: Tight Gear Handle
--> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au.matronics.org>
http://forums.matronics.com/viewtopic.php?p=513459#513459
_-============================================================
_-= - The Yak-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Yak-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> https://matronics.com/contribution
draftsjust417(at)gmail.co Guest
Posted: Sun Apr 21, 2024 10:28 am Post subject: Tight Gear Handle |
Just curious if the tight gear handle issue was resolved?Always like to hear the resolution-
Thanks-Â Justin/N280NC
On Wed, Apr 10, 2024, 21:13 JL2A <info(at)flyingwarbirds.com.au.matronics.org (info(at)flyingwarbirds.com.au.matronics.org)> wrote:
Quote: | --> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au.matronics.org (info(at)flyingwarbirds.com.au.matronics.org)>
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
jonboede(at)hotmail.com Guest
Posted: Sun Apr 21, 2024 11:34 am Post subject: Tight Gear Handle |
Kind-of sounds like the face of the selector is going bad, maybe?
Would be curious to know, too.
Quote: | On Apr 21, 2024, at 1:32 PM, Justin Drafts <draftsjust417(at)gmail.com> wrote:
 Just curious if the tight gear handle issue was resolved? Always like to hear the resolution-
Thanks- Justin/N280NC
WIKI -
JL2A
Posted: Sat May 04, 2024 10:46 pm Post subject: Re: Tight Gear Handle |
Yeah still stiff - useable but not optimal
Handle is now leaking pretty good in neutral position. As predicted.
Will have to replace, again. We swap dessicant every 25 hours but might have to tighten that up.
Mark Pennington
Joined: 18 Jul 2022 Posts: 10 Location: Richmond Virginia
Posted: Mon May 06, 2024 4:02 am Post subject: Tight Gear Handle |
Gear Handle problems
Shoot me an email address that I can shoot some info to you. I have had the same gear handle in my plane for 5 years.
I was changing mine pretty often. I fly a CJ.
Happy to share my experience and the fix. I think you're in Australia or I would say give me a call...and you can if you would like.
Mark Pennington
N621CJ
Richmond VA
804-399-4224
pennington.construction.inc.1(at)gmail.com (pennington.construction.inc.1(at)gmail.com)
On Sun, May 5, 2024 at 2:50 AM JL2A <info(at)flyingwarbirds.com.au.matronics.org (info(at)flyingwarbirds.com.au.matronics.org)> wrote:
http://forums.matronics.com/viewtopic.php?p=513550#513550
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
_________________ Responding from my iPhone, please disregard any typos. |
