Ts 06 bushing
wdaniell.longport(at)gmai
PostPosted: Tue Mar 26, 2024 6:10 pm    Post subject: Ts 06 bushing Reply with quote
I have a little play in my trim tab ..one of the ts06 bushes is slightly worn.   Does anyone have a source of these other than europa?
(Its not the hinges)
I am wondering if one of the plastic bushings from mcmaster carr...like https://www.mcmaster.com/product/6362K204 would work.
Thoughts anyone?
William Daniell
+1 786 878 0246
rlborger(at)mac.com
PostPosted: Wed Mar 27, 2024 2:30 pm    Post subject: Ts 06 bushing Reply with quote
William,
Sure, if you can find one that fits well, it’s worth a try.
Let us know how it goes.
Blue skies and tailwinds,
Bob Borger
Europa XS Tri, ROTAX 914, Airmaster C/S Prop
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop
2705 Lynchburg Dr
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Mar 26, 2024, at 21:13, William Daniell <wdaniell.longport(at)gmail.com> wrote:
Thoughts anyone?
William Daniell
+1 786 878 0246
Area-51
PostPosted: Wed Mar 27, 2024 11:11 pm    Post subject: Re: Ts 06 bushing Reply with quote
If you had the stock dimensions you could have them turned up in Delrin perhaps. Just a thought; not sure what material the factory originals are... mine are a bit sloppy and rattle a bit at certain attitudes.
PostPosted: Thu Mar 28, 2024 9:36 am    Post subject: Ts 06 bushing Reply with quote
Can anyone tell me the thickness of the tube into  which the ts06 goes?.
The od is 1/2"
Will
William Daniell
+1 786 878 0246
On Thu, Mar 28, 2024, 03:13 Area-51 <goldsteinindustrial(at)gmail.com (goldsteinindustrial(at)gmail.com)> wrote:
--> Europa-List message posted by: "Area-51" <goldsteinindustrial(at)gmail.com (goldsteinindustrial(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=513425#513425
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
PostPosted: Thu Mar 28, 2024 10:23 am    Post subject: Ts 06 bushing Reply with quote
Good to know...
I only noticed it because i put some welding rods into the hinges which took up the hinge play.
Its maybe 1/16 at the end of the trim tab
Thanksa
William Daniell
+1 786 878 0246
WIKI -
