Trailing edge elevator deflection issue
tonyvaccarella
PostPosted: Mon Mar 18, 2024 4:46 am    Post subject: Trailing edge elevator deflection issue Reply with quote
Hello intrepid flyers,
An inspection recently showed that the trailing edge deflection on my Europa XS was not to spec. We adjusted the rod-ends at the end of the pitch tube but we only managed to get 12 deg up and 3 deg down (total of 15 deg overall deflection). Any further adjustments would either provide an increase in the up direction with a corresponding reduction in the down direction - maintaining the 15 degree overall deflection.
Mass balance weight does not touch its limits and the anti-servo T-Bar is free and does not hit the fusalage.
Can some wise builder advise the method used to increase the full deflection range - Id like to get about 16 to 18 degrees if possible.
Many thanks to all
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
Duncan McFadyean
PostPosted: Mon Mar 18, 2024 5:41 am    Post subject: Trailing edge elevator deflection issue Reply with quote
Check that all other linkages in the elevator system are working at maximum gearage, i.e. the geometry of all other pushrods and horns are at right angles when at the middle of their range. If too oblique, there will be loss of range.
Duncan McF.
Many thanks to all
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=513387#513387
budyerly@msn.com
PostPosted: Mon Mar 18, 2024 7:01 am    Post subject: Trailing edge elevator deflection issue Reply with quote
Tony,
If our stab mechanism is hitting the mechanical mass balance limits at the mass balance arm and you are sure the pitch tube MW bearings are clear on the pitch torque tube (CS10) in the wing center and there is not mechanical binding there, look at the following:
It is quite easy technically to adjust the incidence of the stabilator by changing the stabilator balance weight upper and lower mass balance stops.
Hopefully you have done the Mod 70, but even if you haven't, it's straight forward. (Mod 70 and or the cable sway supports with original TP18 fittings can still can be adjusted easily).
You are essentially looking to have +13,-5 or a minimum of +12,-4 degrees of trailing edge travel so 16-18 degrees total from full up to down.
Simply carve the upper and lower slots to get the total travel plus the bump stop rubber and reinstall the bump stop rubbers and recheck.
I have an archived a document somewhere, but the main issue is the uncomfortable access if the viewing/inspection plates are small.
I see this all the time on prebuy inspections and it can be an 2-8 hour exercise but it is worth it to get the stab incidence right.
The amount to actually relieve the current stops starts with measurement of course.
I personally pull off the installed upper rubber stop (as many builders fail to adjust for the bump stop thickness) on the top and sometimes the bottom to make my adjustment but always measure and look first. In some cases a large upper stop has been made that has about 20mm between the wood cutout and the fuselage inside top surface. Remove the rubber bump and Demel out the arc to suit your stab throw needs to increase the TE down (mass balance hitting the top stop). Some have the upper mass balance stop nearly at the upper skin so you have the lower limit to move only. In your case with only needing a degree, pull the top rubber stop off and see if you can relieve that a bit, then reinstall your rubber bumper and install a stick between the lower stop and the weight to hold the stop firmly until it dries. To make it pretty, get the arc set by using a thin metal strip bent to a pleasing arc while holding the mass balance firmly to the stop limit.
If you have a nose down of -4 degrees and just need a bit on the up stop limit, the rubber bolted wood dowel normally can be changed. This can be changed by simply moving the lower stop down a bit (filling and redrilling) or if clearances are an issue with the stab push pull tube, 3D printing a smaller cylinder or by center drilling a smaller wood dowel and fitting a rubber hose sized properly to get more trailing edge up to suite your throw needs.
Once the total throw is as you desire (normally 17 degrees (+13,-4)) but you cut or modified both the upper and lower stops, there is little chance that the new top and bottom stops are perfect, so one must remove the stabs (for ease of access) and "simply" remove the TP18 adjustment body bolts and adjust the mass balance arm and reassemble as necessary to get the stab mechanical stops up front to clear nicely. That is time and patience consuming to get the desired +13 to -5 hence, 17 degrees may be a better option. And this is where the time and patience grows thin. Suck it up and make a pin to replace the bolt to make adjustments of the TP18C easier. Then reinstall the bolt while forcing the pin you made and bolt it up. Carefully and patiently readjust the full down limit to -4 degrees to -5 degrees so the pitch tube doesn't bind on the torque tube (full forward stick also not hitting the panel). If the controls were built per the manual, you now should only have the trailing edge up or stick aft issue to get adjusted. Again, if the torque tube arms in the center tunnel don't hit the limit at the roll tube arm CS08. If you have issues with the original build in this clearance, much adjusting will be necessary to allow the stick movement, pushrods, arms and torque tube to work properly. Then you have the issues of push rod adjustment and perhaps even stab push tube lengthening to contend with. I've done them all and it can try ones patience but it is worth it in the end.
To be honest, if you have a weight and balance near 60 per the manual, +12-4 stab travel is quite acceptable. If it is a nose heavy or tail heavy beast, then go for full travel.
If you notice the left and right stab incidence is noticeably different then a bit of extra work will make all that work out also, see pdf attached.
Whatever you do, the mechanical bolts and metal fittings can't bind at the cockpit module linkages. If you can adjust only one stop, life is good. If you must adjust both, and then find the limit is with the pitch tube hitting the mechanical limits. Life will suck a bit. Then we must adjust the stick travel and limits to just clear and then go back to the stab stop limits and continue aft until all is well.
I've only had two cups of coffee, so email back if you need more clarification Tony.
Best Regards,
Bud Yerly
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of tonyvaccarella <tony(at)weimagine.com.au>
Sent: Monday, March 18, 2024 8:46 AM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: Trailing edge elevator deflection issue
--> Europa-List message posted by: "tonyvaccarella" <tony(at)weimagine.com.au>
Many thanks to all
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D513387%23513387&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861228628%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=u5uWqVQ6h9Af7d3XGhj%2FikYeo3DeEtk289vdqBST%2BAk%3D&reserved=0
st Email Forum -
pa-List" id="OWAa3580483-28e8-8751-7c93-52c50f8bf789" class="OWAAutoLink" data-auth="NotApplicable"> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861242995%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=3CJg7INhDjFzwZ%2BCP6pbSsXTx4GhjEZEV7V2emOhgf0%3D&reserved=0
p; - MATRONICS WEB FORUMS -
9db88f5a-fddc-5f73-028a-926356768c33" class="OWAAutoLink" data-auth="NotApplicable"> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2F&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861255912%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=eDLD%2BWCNhAxoZTkDWMCqgdBjco5EqjeTqKEvzRyrGzA%3D&reserved=0
5aaade-a7b6-9e45-a7cf-14043b7b5bae" class="OWAAutoLink" data-auth="NotApplicable"> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwiki.matronics.com%2F&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861267765%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=G%2Bo9ZUKTY3lKMBSYkHIM4xsg2HIE1V2G0E70SO98Yik%3D&reserved=0
p;   -Matt Dralle, List Admin.
="OWAbc9fcc66-fc01-3799-4f93-a92129e8aec8" class="OWAAutoLink" data-auth="NotApplicable"> https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fmatronics.com%2Fcontribution&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861278512%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=I6T5XrhwaGi1DmFH5zCDgm8uguHrKNvAWOEITNQx3wk%3D&reserved=0
Technique_for_getting_stab_incidence_and_trim_tab_incidence.pdf
 Filename:  Technique_for_getting_stab_incidence_and_trim_tab_incidence.pdf
 Filesize:  233.32 KB
 Downloaded:  415 Time(s)
tonyvaccarella
PostPosted: Mon Mar 18, 2024 6:40 pm    Post subject: Trailing edge elevator deflection issue Reply with quote
Hi Bud,
As always - a very informative reply.
As it stands now - the mass balance arm top or bottom dont come anywhere near the stops - so thats not the issue - what else can I look at?
What I dont understand is that I originally check this before first flight an we were getting bout 14 deg up and on rechecking this weekend I barely got 9 deg up.
Its got me scratching my head.
Tony
On Mon, 18 Mar 2024 15:00:39 +0000, Bud Yerly <budyerly(at)msn.com> wrote:
Tony,
Best Regards,
Bud Yerly
Many thanks to all
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
st Email Forum -
e" href="http://www.matronics.com/Navigator?Europa-List" id="OWAa3580483-28e8-8751-7c93-52c50f8bf789"> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861242995%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=3CJg7INhDjFzwZ%2BCP6pbSsXTx4GhjEZEV7V2emOhgf0%3D&reserved=0
e" href="http://forums.matronics.com/" id="OWA9db88f5a-fddc-5f73-028a-926356768c33"> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2F&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861255912%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=eDLD%2BWCNhAxoZTkDWMCqgdBjco5EqjeTqKEvzRyrGzA%3D&reserved=0
e" href="http://wiki.matronics.com/" id="OWA275aaade-a7b6-9e45-a7cf-14043b7b5bae"> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwiki.matronics.com%2F&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861267765%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=G%2Bo9ZUKTY3lKMBSYkHIM4xsg2HIE1V2G0E70SO98Yik%3D&reserved=0
e" href="https://matronics.com/contribution" id="OWAbc9fcc66-fc01-3799-4f93-a92129e8aec8"> https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fmatronics.com%2Fcontribution&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861278512%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=I6T5XrhwaGi1DmFH5zCDgm8uguHrKNvAWOEITNQx3wk%3D&reserved=0
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
Area-51
PostPosted: Tue Mar 19, 2024 3:25 am    Post subject: Re: Trailing edge elevator deflection issue Reply with quote
If the mass balance is contacting one stop and not the other that would indicate something in the control circuit has slipped. If the mass balance is not making contact with either stop then that would indicate component binding somewhere in the control circuit.
Removing the stabilators and then retest from control stick end is one diagnostic.
Removing pins at the base of the cockpit control sticks and retest movement from stabilator end is another diagnostic.
Remaining control circuit isolation point is at the forward control tube joint in the spar void.
DuaneFamly
PostPosted: Tue Mar 19, 2024 11:04 am    Post subject: Trailing edge elevator deflection issue Reply with quote
I’m referring to XS build manual on page 13-13. But remember, the diagram is upside from what you are looking at inside the fuselage. If you happen to take the wings off, look into fuselage on the starboard side at the CS10 pitch torque tube where the CS08 aileron crank comes close to it when the control stick is hard left. On mine, I actually have a small nick in the paint on the pitch torque tube from the aileron crank contacts it. The port side crank comes really close when hard right but no nick yet. Are yours coming this close? If not, something is keeping the CS05 torque tube is not rotating sufficiently.Were the two CS08 cranks parallel to each other once the cross-link rod (fig12 pg 13-9) was attached?
I would next check CS02 the control stick fork for interferences.
Good luck.
Mike Duane N377EA
Europa XS Conventional Gear
Chandler, AZ
Sent from the all new AOL app for iOS
On Tuesday, March 19, 2024, 04:29, Area-51 <goldsteinindustrial(at)gmail.com> wrote:
--> Europa-List message posted by: "Area-51" <goldsteinindustrial(at)gmail.com (goldsteinindustrial(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=513393#513393
http://www.matronics.com/Nanbsp; - MATRONICS WEB FORUMS -http://wiki.matronics.com[/url]
https://matronics.co=
Mike Duane
