rparigoris
Posted: Fri Mar 08, 2024 1:56 pm Post subject: Baggage area tie downs |
Hi Group
In process of painting interior of our XS Mono. Using Rustoleum Universal Bonding Primer and Rustoleum Hammered for top coat. Using several colors.
Question: What are you using for tie down points in baggage area for rope or netting?
Thx.
Ron P.
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Sat Mar 09, 2024 4:59 am Post subject: Re: Baggage area tie downs |
I use a smallish net which came with my Skoda car i.e. a VW made in the Czech Republic, with four hooks, one at each corner. The anchor points for each hook are medium / small cable tie wraps.
Four small holes, similar diameter to the width of the tie wraps, are drilled through the baggage bay bulkhead at about the same level as the "headrests" and through each "headrest". A cable tie is passed through each hole from the opposite side to where the net hook will attach and then pushed back through the same hole. Each cable tie then gets zipped, leaving four loops as anchors on the headrests and rear bulkhead.
