Mag Timing CD5
glipaz
PostPosted: Fri Feb 02, 2024 9:52 am    Post subject: Mag Timing CD5 Reply with quote
Brain trust:
I know that on an M-14p with a Russian M9F magneto, timing on the prop is set at 14-16* BTDC. This translates to around 22-24* BTDC on the crank.
Assuming an M-14p motor with CD-5 (Chinese)magnetos stamped 25*, what is the proper angle on the prop BTDC?
According to Craig Payne’s chart for this configuration it suggests 8.8* BTDC on the crank and 5.8* BTDC on the prop. I don’t understand this figure.
Gil
richard.goode(at)russiana
PostPosted: Sat Feb 03, 2024 3:44 am    Post subject: Mag Timing CD5 Reply with quote
It is not quite so simple – but the attached paper might help!
Richard
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)
www.russianaeros.com
WORLD LEADERS IN SOVIET & CHINESE RADIAL AIRCRAFT ENGINES
In partnership with Aerometal Kft, Hungary.
Magneto_and_Air_Distributor_Timing.pdf
 Filename:  Magneto_and_Air_Distributor_Timing.pdf
 Filesize:  230.95 KB
 Downloaded:  846 Time(s)
draftsjust417(at)gmail.co
PostPosted: Sat Feb 03, 2024 10:22 pm    Post subject: Mag Timing CD5 Reply with quote
Very good document Richard, thanks!
Do you have such a document for the Chinese Housai?
Justin Drafts
N280NC
On Sat, Feb 3, 2024 at 3:50 AM Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
Richard
PostPosted: Sun Feb 04, 2024 2:50 am    Post subject: Mag Timing CD5 Reply with quote
I am afraid not precisely. Of course the CD-5 has internal advance like the M9-35M Russian magneto but I'm afraid at the weekend I simply don't know whether, like the Russian magneto, there are different "series" stamped onto the side of the magneto giving different degrees of advance. But I assume you have the Chinese maintenance manual which covers magneto timing in detail. If not please send us an email and we will send you the link to download the manual – this is a free service for anyone who could be interested. Richard.
WORLD LEADERS IN EAST EUROPEAN & CHINESE RADIAL AIRCRAFT ENGINES
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> On Behalf Of Justin Drafts
Sent: 04 February 2024 06:22
To: yak-list(at)matronics.com
Subject: Re: Mag Timing CD5
Justin Drafts
N280NC
Richard
 Filesize:  5.62 KB
 Viewed:  11734 Time(s)
 Filesize:  5.26 KB
