mike(at)vision499.com Guest
Posted: Mon Jan 29, 2024 10:54 am Post subject: Access to parts |
Hello
I popped two seals on my Constant speed prop.
Have not been able to get a response from the factory, any ideas on who may be able to help getting spares?
A passer by at the airport said he saw many LOM’s flying in Europe so it may just be a language problem
Keep well
Mike Pienaar
mike(at)vision499.com (ike(at)vision499.com)
Mike cell: +1 250-885-0554
1-1100 Tulip Ave, Victoria, BC, V8Z 0A2
| | - The Matronics Lom-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
sjbeaver(at)gmail.com Guest
Posted: Mon Jan 29, 2024 10:55 am Post subject: Access to parts |
Which factory did you attempt to contact? LOM, Avia, Hamilton Standard? Steve-- Stephen Beaver
Als ik kanTel: 614-937 4189
| Quote: | On Jan 29, 2024, at 1:53 PM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Hello
Keep well
Mike Pienaar
mikepienaar09(at)gmail.co Guest
Posted: Mon Jan 29, 2024 11:31 am Post subject: Access to parts |
Hello Steve,
I replied to the e-mail address on the LOM website. Did not think of contacting Avia or Hamilton Standard
Mike
From: owner-lom-list-server(at)matronics.com <owner-lom-list-server(at)matronics.com> On Behalf Of sjbeaver
Sent: Monday, January 29, 2024 10:56 AM
To: Lom-List Digest Server <lom-list(at)matronics.com>
Subject: Re: Access to parts
Steve
Stephen Beaver
Als ik kan
Tel: 614-937 4189
Hello
Keep well
Mike Pienaar
Posted: Mon Jan 29, 2024 11:40 am Post subject: Access to parts |
Try http://www.aviapropeller.cz/index.htm they supply parts for the props. LOM have been very responsive recently, but they don’t support the props.
I converted my LOM M332 AK to fixed pitch operation, so I have a CS prop, governor, nose case/seal assembly and plumbing available, but I don’t have any spare seals and it may not even be your model prop. It came off a Glasstar.
Steve--
Als ik kan
| Quote: | On Jan 29, 2024, at 2:31 PM, mikepienaar09(at)gmail.com wrote:
(at)font-face { font-family: "Cambria Math"; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: "Comic Sans MS"; } p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm; font-size: 11pt; font-family: Calibri, sans-serif; } a:link, span.MsoHyperlink { color: blue; text-decoration: underline; } span.apple-converted-space { } span.EmailStyle19 { font-family: Calibri, sans-serif; color: windowtext; } .MsoChpDefault { font-size: 10pt; } (at)page WordSection1 { size: 612pt 792pt; margin: 72pt; } div.WordSection1 { page: WordSection1; } <![endif]--> <![endif]-->
Hello Steve,
Mike
Steve
Stephen Beaver
Als ik kan
Tel: 614-937 4189
Hello
Keep well
Mike Pienaar
Posted: Mon Jan 29, 2024 6:01 pm Post subject: Access to parts |
Not that I am contemplating it now but how big a job was it to convert to fixed pitch and why did you do it.Thanks for your help
Where will I be able to get spark plugs?
Keep well
On Mon., Jan. 29, 2024, 11:40 a.m. sjbeaver, <sjbeaver(at)gmail.com (sjbeaver(at)gmail.com)> wrote:
| Quote: | Try http://www.aviapropeller.cz/index.htm they supply parts for the props. LOM have been very responsive recently, but they don’t support the props.
Steve--
Als ik kan
| Quote: | On Jan 29, 2024, at 2:31 PM, mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com) wrote:
Hello Steve,
Mike
From: owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com) <owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com)> On Behalf Of sjbeaver
To: Lom-List Digest Server <lom-list(at)matronics.com (lom-list(at)matronics.com)>
Steve
Stephen Beaver
Als ik kan
Tel: 614-937 4189
Hello
Keep well
Mike Pienaar
Posted: Mon Jan 29, 2024 7:23 pm Post subject: Access to parts |
It is very simple. Basically a 30 mm plug is installed in the nose of the crankshaft, the governor is removed along with its associated plumbing and that's it. My a/c is a 1930s Bücker Jungmann on which a CS prop would be out of place.
For spark plugs, use the NGK plugs as I have documented here: https://bucker.info/index.php/component/content/article?id=1625 Steve-- Stephen Beaver
| Quote: | On Jan 29, 2024, at 9:00 PM, mike Pienaar <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> wrote:
Keep well
Steve--
Als ik kan
Hello Steve,
Mike
From: owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com) <owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com)> On Behalf Of sjbeaverSent: Monday, January 29, 2024 10:56 AMTo: Lom-List Digest Server <lom-list(at)matronics.com (lom-list(at)matronics.com)>Subject: Re: Access to parts
Hello
Keep well
Mike Pienaar
Posted: Mon Jan 29, 2024 7:54 pm Post subject: Access to parts |
Thanks very much for your helpThat article you wrote is well done and I much appreciate the info and effort you put into it
On a different note, what language is "als ik kan"?
On Mon., Jan. 29, 2024, 7:23 p.m. sjbeaver, <sjbeaver(at)gmail.com (sjbeaver(at)gmail.com)> wrote:
| Quote: | It is very simple. Basically a 30 mm plug is installed in the nose of the crankshaft, the governor is removed along with its associated plumbing and that's it. My a/c is a 1930s Bücker Jungmann on which a CS prop would be out of place.
Steve
Stephen Beaver
Als ik kan
Tel: 614-937 4189
Keep well
Steve--
Als ik kan
Hello Steve,
Mike
Steve
Stephen Beaver
Als ik kan
Tel: 614-937 4189
Hello
Keep well
Mike Pienaar
Posted: Mon Jan 29, 2024 9:26 pm Post subject: Access to parts |
The phrase comes from from Jan van Eyck, a 15th century Renaissance artist who signed his paintings with the personal motto Als Ik Kan, which is taken from the Flemish saying “As I can, not as I would.” Steve-- Stephen Beaver
| Quote: | On Jan 29, 2024, at 10:54 PM, mike Pienaar <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> wrote:
Keep well
Steve--
Als ik kan
Hello Steve,
Mike
Hello
Keep well
Mike Pienaar
