Posted: Mon Dec 18, 2023 6:06 am Post subject: OVM-14 MkIII development (update) |
All the proto boards and parts are in.
This is a busy time for festivities and frivolities . . .
having trouble getting back to the bench.
I'm going to try something 'new' for my shop.
The big guns in electronic assembly literally
silk screen solder paste onto component pads
before using a pick-n-place machine to position
parts. The boards are then run through a very
sophisticated oven that preheats and then
flows the solder.
I remember my first experiences with solid state
assembly protocols. 1955 or thereabouts I acquired
my first transistor. A Raytheon CK722. Seems like
they cost about $6 then. All the instructions
for assembling the device into the circuit called
for grabbing the lead with a pair of needle nose
pliers to keep the soldering heat from migrating
up and into the device placing it at risk for
failure.
Nowadays, we can throw whole assemblies into
environments that solder thousands
of joints all at once in mere minutes . . .
I've purchased a hand operated syringe designed
to deposit mosquito poop sized drops of solder
paste onto the pads. I also have a miniature
heat-gun with which I can stick every thing down
in one operation.
I've scheduled some time with my contractor to
modify a workbench in the 'mess making' shop.
We're adding some shelving to support test equipment
over the alternator drive I built up several
years ago for another project. I'm planning to
instrument a mock-up of a complete electrical
system so that we can speak to performance
of system components in terms of measured values.
Watch this space.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
bob.verwey(at)gmail.com Guest
Posted: Mon Dec 18, 2023 7:22 am Post subject: OVM-14 MkIII development (update) |
Bob my optical focus is more and more a challenge when dealing with more and more minutuarized components!
On Mon, 18 Dec 2023, 16:09 Robert L. Nuckolls, III, <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | All the proto boards and parts are in.
flows the solder.
failure.
in one operation.
Watch this space.
(o o)
rv8iator
Posted: Mon Dec 18, 2023 7:28 am Post subject: OVM-14 MkIII development (update) |
Bob et al...
This is a BGA component (Dims in mm) that is soldered to a slightly larger motherboard. All our fabs are pick and place. Most boards 6 layers with .010 in traces. We get some components that are manufactured in millimeters and our design software (Altium) likes inch grids... The conversion is four significant digits so it's only a matter of making sure you remember what units you are working in...
I only bring this up as boards and fab have really become quite inexpensive. I do 5 piece and 10 piece board proto lots.
Fun stuff!
.Chris
Another RV
[img]cid:ii_lqb28zcx0[/img]
On Mon, Dec 18, 2023 at 6:09 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
flows the solder.
failure.
in one operation.
Watch this space.
(o o)
40.03 KB |
10056 Time(s) |
_________________ C. Stone (RV8iator) |
Ceengland
Posted: Mon Dec 18, 2023 8:38 am Post subject: OVM-14 MkIII development (update) |
On Mon, Dec 18, 2023 at 8:09 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
flows the solder.
snip
in one operation.
snip
| Quote: | of system components in terms of measured values.
Watch this space.
| A friend of mine designed and has been making the control head/monitors for E-Mag ignition systems for many years, using surface mount components. He copied what hobbyists were doing; they used a particular brand of 'toaster oven' that has accurate temperature control. So if you have an E-Mag control head, it came from an 'easy bake oven'.
Charlie
Virus-free.www.avast.com[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
_________________ Charlie |
Posted: Mon Dec 18, 2023 10:04 am Post subject: OVM-14 MkIII development (update) |
At 09:21 AM 12/18/2023, you wrote:
| Quote: | | Bob my optical focus is more and more a challenge when dealing with more and more minutuarized components! |
Yeah . . . While at Beech, I purchased a binocular
microscope with a camera port. Invaluable tool for
chasing down root cause for sticking relays, broken
shafts, poor craftsmanship, etc. Now it's handy
for working etched circuit boards! I don't use
anything smaller than 1206 components but the
next gen OVM got laid out really tight so the
board will STILL fit under 1/2" heat shrink.
I'm thinking of seeing if some of my contractor's
grand kids would be interested in learning to
assemble things like this. Thought it would
be wise to pursue an upgrade to our shade-tree
processes. The poop-n-blast technique seems
like a logical 'upgrade'.
(o o)
Posted: Mon Dec 18, 2023 11:21 am Post subject: OVM-14 MkIII development (update) |
| Quote: | A friend of mine designed and has been making the control
Yeah, I've been aware of a constellation of
reflow tools for DIY assembly for a number
of years. About 10 years ago, I bought an
early version of this thing.
Made it work okay . . . but it took up a lot
of room on the bench and was a tool I used
for perhaps an 2 hours per month. It was
just not very practical for my products
with tiny boards. Still had some thru-hole
products that were not oven-friendly.
My little hot-air rework station seemed
to be a better fit for my mix of repair/
manufacturing tasks. Didn't take up much
room. Virtually zero 'set up' . . . one
could visually adjust technique on the
fly. Was a whole lot cheaper too!
I'm reminded of the exciting day that
we purchased a wave soldering machine
at Electro-Mech. We kept it for less
than a year. There was a lot of 'back-office'
work to store up enough boards to justify
firing the thing up for a run . . . that
might take less than an hour to solder a
months worth of production.
The thing proved to be a bottle-neck in
work flow for an operation that produced
a relatively small quantities of dozens of
products that were needed at the customer
in a smooth JIT flow.
Our assembly line of skilled craftspersons
proved more practical for managing
work-flow.
(o o)
109.69 KB |
10040 Time(s) |
Eric Page
Posted: Mon Dec 18, 2023 3:07 pm Post subject: Re: OVM-14 MkIII development (update) |
Those Chinese T-962 reflow ovens are well known in the hobbyist community for having hot and cold spots, sometimes poor internal wiring, and for not following IPC profiles very well. There's an open-source project out there for a replacement controller that makes them work better.
I use an old toaster oven with a failed thermostat that makes it run full blast regardless of setting (I ate out the day that happened!). I picked up a cheap industrial ramp/soak PID controller to run it. The only modification necessary was to cover the inside of the window in its door with aluminum foil to minimize radiated heat loss. It now works like a charm and cost only a few dollars.
If you want to build a toaster oven reflow setup, look for an oven with quartz heating elements; they're reputed to allow faster temperature ramps, making it easier to follow the right profile.
-Eric
Posted: Mon Dec 18, 2023 7:33 pm Post subject: OVM-14 MkIII development (update) |
At 05:07 PM 12/18/2023, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Eric Page" <edpav8r(at)yahoo.com>
Those Chinese T-962 reflow ovens are well known in the hobbyist community for having hot and cold spots, sometimes poor internal wiring, and for not following IPC profiles ( https://www.ipc.org/TOC/IPC-7801.pdf) very well. There's an open-source project out there for a replacement controller that makes them work better.
Good info sir. Thank you!
I think the T-962 has evolved to mitigate some
of its shortcomings. The one I bought needed
a number of mods right out of the box . . but
it ultimately seemed adequate . . . jut more
than I needed. Kinda like doing in ants
with a sledgehammer!
(o o)
