werner schneider
Posted: Fri Dec 01, 2023 3:09 pm Post subject: 3 stage switching for lights |
Hi Folks,
I wonder if I could save on a 4th dimmer Here what I want to achieve:
Cabin lights (LED) 2 section, front and rear:
-position 1, front lights on dimmer, rear lights off
-position 2, front and rear lights on dimmer
-position 3, front lights off, rear lights on 13.8V
I did craft a scheme, but I'm not able to find a switch which offer that 3 stage functionality or maybe I'm just not good enough in wiring it for that functionality.
Thanks for your help (due to space constrains the switch would need to use screw terminals in addition)
Werner
Ceengland
Posted: Fri Dec 01, 2023 6:07 pm Post subject: 3 stage switching for lights |
On 12/1/2023 5:09 PM, werner schneider wrote:
| Quote: | | Quote: | --> AeroElectric-List message posted by: "werner schneider" <glastar(at)gmx.net> (glastar(at)gmx.net)
Hi Folks,
Werner
| | Apologies for the inevitable question in answer to a question:
Will you be the only person who manipulates the system? Because anything other than 3 controls seems like head-down time for anyone not well schooled in its operation.
Charlie
Virus-free.www.avast.com[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
_________________ Charlie |
werner schneider
Posted: Sat Dec 02, 2023 4:08 am Post subject: 3 stage switching for lights |
Hello Charlie,
good question to consider, it's in a center overhead console and I guess 90 of the time the switch would be in the center position (dimmer for both), the rear position (light rear only is out of my view for ground operation) the front would be if the rear passengers are asleep.
[img]cid:part1.WgbUp0k8.XoPxwv9x(at)gmx.net[/img]
So I would estimate the switch itself will be operated not to many times. But your question might lead me just to a 4th dimmer for rear only and maybe even positioned so the rear pax can handle it themself.
Thanks for your always very well valued hints and tips Charlie!
Werner
On 02.12.2023 03:11, Charlie England wrote:
Hi Folks,
Werner
Charlie
Virus-free.www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
19.66 KB |
22663 Time(s) |
rv8iator
Posted: Sat Dec 02, 2023 7:01 am Post subject: 3 stage switching for lights |
Many from on-line vendors:https://www.amazon.com/GAMA-Electronics-Toggle-Switch-Position/dp/B001PNMC16
https://www.steinair.com/product/toggle-switch-3-position-dpdt/
https://bandc.com/product/toggle-switch-double-pole/?attribute_configuration=-10+ON-ON-ON
On Fri, Dec 1, 2023 at 3:12 PM werner schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: "werner schneider" <glastar(at)gmx.net (glastar(at)gmx.net)>
Hi Folks,
Werner
http://forums.matronics.com/viewtopic.php?p=512721#512721
WIKI -
_________________ C. Stone (RV8iator) |
werner schneider
Posted: Sat Dec 02, 2023 7:24 am Post subject: 3 stage switching for lights |
Thanks Christopher,
but they do not work as they have not 3 independent position
[img]cid:part1.qand01en.SKawBNOz(at)gmx.net[/img]
it's always a set of 2 closed so eg. if you feed from 5 and 2 you could do 5-4 up, 5-6 middle but then down you would have 2-3 but 5-6 would be closed as well
On 02.12.2023 16:00, Christopher Cee Stone wrote:
| Quote: | Many from on-line vendors: https://www.amazon.com/GAMA-Electronics-Toggle-Switch-Position/dp/B001PNMC16
Hi Folks,
Werner
WIKI -
55.37 KB |
22662 Time(s) |
rv8iator
Posted: Sat Dec 02, 2023 7:32 am Post subject: 3 stage switching for lights |
[img]cid:ii_lpo7ldww1[/img]
Take at the functions. It appears to me this is what you want.
Also
https://www.ebay.com/itm/293559818578?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=293559818578&targetid=1490630670660&device=c&mktype=pla&googleloc=9032917&poi=&campaignid=19851828444&mkgroupid=145880009014&rlsatarget=pla-1490630670660&abcId=9307249&merchantid=114784040&gclid=Cj0KCQiAyKurBhD5ARIsALamXaHdlww9Fe9Yu1ydQyAe6anUXRiGz4KA3n6oG3-clEaFpkyQR-CLpzUaAsIYEALw_wcB
...chris
On Sat, Dec 2, 2023 at 7:26 AM Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:
| Quote: | Thanks Christopher,
[img]cid:ii_18c2b25c54dcc363cd1[/img]
Hi Folks,
Werner
WIKI -
55.37 KB |
22661 Time(s) |
810.1 KB |
22661 Time(s) |
bobkuc(at)gmail.com Guest
Posted: Sat Dec 02, 2023 8:33 am Post subject: 3 stage switching for lights |
I would think that you need a 4 position switch since off position would be needed. I would just go with 2 switches, but if you want only one then look at a 4 position rotary switch.
1 off
2 front
3 back
4 both
On Sat, Dec 2, 2023, 10:37 AM Christopher Cee Stone <rv8iator(at)gmail.com (rv8iator(at)gmail.com)> wrote:
| Quote: | [img]cid:ii_lpo7ldww1[/img]
Also
...chris
Hi Folks,
Werner
WIKI -
55.37 KB |
22657 Time(s) |
810.1 KB |
22657 Time(s) |
werner schneider
Posted: Sat Dec 02, 2023 9:16 am Post subject: 3 stage switching for lights |
Christopher, that is the same as below, due to 2 feeds it does not work
Cheers Werner
On 02.12.2023 16:31, Christopher Cee Stone wrote:
| Quote: | [img]cid:part1.vZaL24vr.Yd3Ovgoe(at)gmx.net[/img]
Also
...chris
[img]cid:part2.iTW4m0cB.8H2z0xo3(at)gmx.net[/img]
Hi Folks,
Werner
WIKI -
810.1 KB |
22651 Time(s) |
55.37 KB |
22651 Time(s) |
werner schneider
Posted: Sat Dec 02, 2023 9:21 am Post subject: 3 stage switching for lights |
Thanks Bob,
The dimmer has the off functionality, so 3 position would work but need
to have 2 feeders, diodes would be against crossfeed here my
architecture, but the switch will not work this way
On 02.12.2023 17:32, Bob Kuc wrote:
[quote] I would think that you need a 4 position switch since off position
1 off
2 front
3 back
4 both
Also
<https://www.ebay.com/itm/293559818578?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=293559818578&targetid=1490630670660&device=c&mktype=pla&googleloc=9032917&poi=&campaignid=19851828444&mkgroupid=145880009014&rlsatarget=pla-1490630670660&abcId=9307249&merchantid=114784040&gclid=Cj0KCQiAyKurBhD5ARIsALamXaHdlww9Fe9Yu1ydQyAe6anUXRiGz4KA3n6oG3-clEaFpkyQR-CLpzUaAsIYEALw_wcB>
...chris
On Sat, Dec 2, 2023 at 7:26 AM Werner Schneider <glastar(at)gmx.net>
wrote:
Thanks Christopher,
> Hi Folks,
> want to achieve:
> Werner
> Electric-List" rel="noreferrer"
> target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
> FORUMS -
> eferrer" target="_blank">http://forums.matronics.com
> WIKI -
> errer" target="_blank">http://wiki.matronics.com
> b Site -
mike_tailwind
Posted: Sat Dec 02, 2023 10:51 am Post subject: 3 stage switching for lights |
That looks like it should work.
I'd pull the feed for switch input pin2 from before the dimmer and use one fuse.
I assume there are series resistors as part of the cabin LEDs to limit current? If, not they are needed.
The LM317 dimmer circuit will not go to a completely off state.
On Saturday, December 2, 2023 at 11:37:32 AM CST, Werner Schneider <glastar(at)gmx.net> wrote:
Thanks Bob, The dimmer has the off functionality, so 3 position would work but need to have 2 feeders, diodes would be against crossfeed here my architecture, but the switch will not work this way [img]cid:i45CqlsWaMHW4lY2lZ6w[/img] On 02.12.2023 17:32, Bob Kuc wrote:
1 off
2 front
3 back
4 both
| Quote: | [img]cid:ryv2KY4sswXRFK5neZYw[/img] Take at the functions. It appears to me this is what you want.
Also
...chris
| Quote: | Thanks Christopher, but they do not work as they have not 3 independent position [img]cid:k8CSnNfR6RRA4kSMUTx8[/img] it's always a set of 2 closed so eg. if you feed from 5 and 2 you could do 5-4 up, 5-6 middle but then down you would have 2-3 but 5-6 would be closed as well On 02.12.2023 16:00, Christopher Cee Stone wrote:
| Quote: | --> AeroElectric-List message posted by: "werner schneider" <glastar(at)gmx.net (glastar(at)gmx.net)> Hi Folks, I wonder if I could save on a 4th dimmer Here what I want to achieve: Cabin lights (LED) 2 section, front and rear: -position 1, front lights on dimmer, rear lights off -position 2, front and rear lights on dimmer -position 3, front lights off, rear lights on 13.8V I did craft a scheme, but I'm not able to find a switch which offer that 3 stage functionality or maybe I'm just not good enough in wiring it for that functionality. Thanks for your help (due to space constrains the switch would need to use screw terminals in addition) Werner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512721#512721 =========== - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== WIKI - errer" target="_blank">http://wiki.matronics.com =========== b Site - -Matt Dralle, List Admin. ="noreferrer" target="_blank">https://matronics.com/contribution =========== |
77.38 KB |
22636 Time(s) |
810.1 KB |
22636 Time(s) |
55.37 KB |
22636 Time(s) |
werner schneider
Posted: Sun Dec 03, 2023 1:48 pm Post subject: 3 stage switching for lights |
Thanks M,
the circuit shown for the dimmer is not exactly the product used, the
Perhelion dimer has an integrated on-off switch. And the LED's are
strips with resistors for 12 V.
The problem I see is, in the position where the rear led strip is on
full voltage via pin 2, the front is as well on the dimmer, that is not
what I want. so that position is not independent. I would like to have 3
independent switch position.
Cheers Werner
On 02.12.2023 19:50, M Wilson wrote:
[quote] That looks like it should work.
one fuse.
Thanks Bob,
1 off
2 front
3 back
4 both
Also
...chris
<mailto:glastar(at)gmx.net>> wrote:
Thanks Christopher,
> <https://www.amazon.com/GAMA-Electronics-Toggle-Switch-Position/dp/B001PNMC16>
> <https://www.steinair.com/product/toggle-switch-3-position-dpdt/>
> <https://bandc.com/product/toggle-switch-double-pole/?attribute_configuration=-10+ON-ON-ON>
> <glastar(at)gmx.net <mailto:glastar(at)gmx.net>> wrote:
> schneider" <glastar(at)gmx.net <mailto:glastar(at)gmx.net>>
> Hi Folks,
> want to achieve:
> Werner
> <http://forums.matronics.com/viewtopic.php?p=512721#512721>
> <http://www.matronics.com/Navigator?AeroElectric-List>
> FORUMS -
> <http://forums.matronics.com>
> WIKI -
> <http://wiki.matronics.com>
> b Site -
mike_tailwind
Posted: Mon Dec 04, 2023 7:30 am Post subject: 3 stage switching for lights |
It looks like you need a DP3T switch. Do a search for them. It seems that it is a 4PDT switch with a jumper. You can search for those also.
The selection seems to be limited. There are several with PC pins and some expensive ones with screw terminals.
I've never used one. They have 12 terminals on the back of the switch, but you don't need any diodes.
See the last page on the attached; it shows the jumper wiring.
On Sunday, December 3, 2023 at 03:58:08 PM CST, Werner Schneider <glastar(at)gmx.net> wrote:
Thanks M, the circuit shown for the dimmer is not exactly the product used, the Perhelion dimer has an integrated on-off switch. And the LED's are strips with resistors for 12 V. The problem I see is, in the position where the rear led strip is on full voltage via pin 2, the front is as well on the dimmer, that is not what I want. so that position is not independent. I would like to have 3 independent switch position. Cheers Werner On 02.12.2023 19:50, M Wilson wrote:
On Saturday, December 2, 2023 at 11:37:32 AM CST, Werner Schneider <glastar(at)gmx.net> (glastar(at)gmx.net) wrote:
Thanks Bob, The dimmer has the off functionality, so 3 position would work but need to have 2 feeders, diodes would be against crossfeed here my architecture, but the switch will not work this way [img][/img] On 02.12.2023 17:32, Bob Kuc wrote:
1 off
2 front
3 back
4 both
| Quote: | [img][/img] Take at the functions. It appears to me this is what you want.
Also
...chris
| Quote: | Thanks Christopher, but they do not work as they have not 3 independent position [img][/img] it's always a set of 2 closed so eg. if you feed from 5 and 2 you could do 5-4 up, 5-6 middle but then down you would have 2-3 but 5-6 would be closed as well On 02.12.2023 16:00, Christopher Cee Stone wrote:
ck_techdata.pdf |
503.7 KB |
934 Time(s) |
Posted: Mon Dec 04, 2023 9:33 am Post subject: 3 stage switching for lights |
At 09:29 AM 12/4/2023, you wrote:
| Quote: | It looks like you need a DP3T switch. Do a search for them. It seems that it is a 4PDT switch with a jumper. You can search for those also.
This may be an option:
This switch has a 'standard' bat-handle and
mounts in the legacy 15/32 hole but has
miniature works on the back. It has enough
poles of specialty operations to get the
functionality you describe.
Not nearly so pricey as it's full-size
cousins.
https://tinyurl.com/ylf6k7gc
https://tinyurl.com/64y4ar53
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
128.95 KB |
22569 Time(s) |
werner schneider
Posted: Mon Dec 04, 2023 2:17 pm Post subject: 3 stage switching for lights |
Thanks Bob,
with the 5A rating that switch has enough "OOMPS" and will perfectly fit my needs ))
appreciated!
Werner
cousins.
(o o)
ChuckGauthier(at)comcast. Guest
Posted: Tue Dec 05, 2023 6:44 am Post subject: 3 stage switching for lights |
Hello Mike,
I have found the following information very helpful in designing unusual toggle switch wiring configurations, which seems to be your case.
Go to Bob's AeroElectric Connection book, Page EX11-2.
Or, use this link on the B&C website: AeroElectric Connection - "Switch Ratings, What's It All Mean?":
https://bandc.com/wp-content/uploads/2018/05/aec_switch_ratings.pdf
There are the pole diagrams for the different toggle switch configurations available through B&C.
One of these might work for you.
Good Luck,
Chuck
werner schneider
Posted: Tue Dec 05, 2023 7:07 am Post subject: 3 stage switching for lights |
Thanks Chuck,
I did that beforehand, however it needs some bridging of some contacts
to achieve what I need, Bob's link did provide that information.
Cheers Werner
On 05.12.2023 15:43, Chuck wrote:
Hello Mike,
werner schneider
Posted: Tue Dec 05, 2023 1:14 pm Post subject: 3 stage switching for lights |
Thanks M,
that is it, sorry got that mail in the spam folder lost before seen now.
Cheers Werner
On 04.12.2023 16:29, M Wilson wrote:
[quote] It looks like you need a DP3T switch. Do a search for them. It seems
Thanks M,
Cheers Werner
one fuse.
<glastar(at)gmx.net> <mailto:glastar(at)gmx.net> wrote:
Thanks Bob,
1 off
2 front
3 back
4 both
Also
...chris
Thanks Christopher,
> Hi Folks,
> want to achieve:
> Werner
> FORUMS -
> WIKI -
> b Site -
