Swaglok valve
jbyak52(at)gmail.com
PostPosted: Sat Oct 14, 2023 7:17 am    Post subject: Swaglok valve Reply with quote
Has anyone replaced the main air system shut-off valve with a Swaglok valve? Seems I remember someone posting a Swaglok part number for the stock valve.
hill(at)doctor-hill.com
PostPosted: Sun Oct 15, 2023 6:53 am    Post subject: Swaglok valve Reply with quote
[img]cid:8FADFA5D-1F6C-45C7-BA8C-9B7F54B2225B[/img]
Warren Hill
N464TW
Mesa, AZ
 Filesize:  239.79 KB
 Viewed:  7606 Time(s)
PostPosted: Sun Oct 15, 2023 7:51 am    Post subject: Swaglok valve Reply with quote
Yes, this is for the CJ. Unsure if the Yak-52 nipples are the same, but if that’s the only issue, some adaptors could possibly be found. This particular Swagelok valve is very robust. I have had it in my CJ for over eight years, and it still works flawlessly. Jill might be able to offer guidance.
On Oct 15, 2023, at 8:26 AM, Jim Burke <jbyak52(at)gmail.com> wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->The Yak 52 valve is different, and the fittings are definitely not NPT. I’ll have to remove the valve to see what will be required to use the Swagelok.
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> On Behalf Of Warren E Hill
Sent: Sunday, October 15, 2023 10:53 AM
To: yak-list(at)matronics.com
Subject: Re: Swaglok valve
<image001.jpg>
Warren Hill
N464TW
Mesa, AZ
On Oct 14, 2023, at 8:16 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:
kingcj6(at)aol.com
PostPosted: Thu Oct 19, 2023 11:58 am    Post subject: Swaglok valve Reply with quote
Warren - what's your best contact number? I'd like to catch up and have a funny story for you.
Dave King
415-806-3100
On Sunday, October 15, 2023 at 07:54:48 AM PDT, Warren E Hill <hill(at)doctor-hill.com> wrote:
[img]cid:UwmJc8n8P8HpsHosG4oy[/img]
Warren Hill
N464TW
Mesa, AZ
 Filesize:  239.79 KB
 Viewed:  7584 Time(s)
