Europa tri-gear wheel change
JonathanMilbank
PostPosted: Sat Oct 28, 2023 12:45 am    Post subject: Europa tri-gear wheel change Reply with quote
How do you jack up a tri-gear to make a main wheel tyre repair or replacement? What kind of adapter / bracket do you take with you when flying away from home base, to facilitate the use of a trolley jack?
Davidcripps
PostPosted: Sat Oct 28, 2023 1:58 am    Post subject: Europa tri-gear wheel change Reply with quote
To remove the wheel I insert a snug fitting solid steel bar into the open end of the axle and jack on that. If you put the jack far enough along the bar away from the wheel, once you’ve got the wheel loose you can then slide the wheel onto the steel bar. You can then support the steel bar or axle stub from the ‘inside’ side of the wheel and hence slide the wheel right off. You do need to be a bit careful not to distort the axle tube, but if the bar fits snugly enough then I’ve not had a problem with this.
I don’t usually carry the bar with me on trips as it’s quite heavy. Would have to look for something similar locally if I had a wheel issue away from base! Maybe a shorter version of the bar might work but you’d then have to rely on temporarily making a support on the bottom end of the leg to get the wheel off.
You can in theory also jack on this end of the gear leg (ie on the inside of the wheel) but it’s an awkward shape too fit a jack to and I feel that jacking there is not very stable.
Hope that helps. Feel free to give me a call if you want more explanation! Message me directly and I’ll send you a number.
Best regards
David
GBWJH
http://forums.matronics.com/viewtopic.php?p=511664#511664
wdaniell.longport(at)gmai
PostPosted: Sat Oct 28, 2023 2:07 am    Post subject: Europa tri-gear wheel change Reply with quote
I use a giant wire cable u clamp round the gear leg with the nuts facing down.  Finger tight is good enough.   These go into any short plank.   This can be used as a platform for a car jack.
Remember to chock all other wheels!!!
William Daniell
+1 786 878 0246
On Sat, Oct 28, 2023, 11:00 Dpc <dpc(at)knightonweb.com (dpc(at)knightonweb.com)> wrote:
--> Europa-List message posted by: Dpc <dpc(at)knightonweb.com (dpc(at)knightonweb.com)>
Best regards
David
GBWJH
> On 28 Oct 2023, at 09:47, JonathanMilbank <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)> wrote:
> --> Europa-List message posted by: "JonathanMilbank" <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)>
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
budyerly@msn.com
PostPosted: Sat Oct 28, 2023 6:45 am    Post subject: Europa tri-gear wheel change Reply with quote
Tire Changes aren't complex and wonderful on the Trigear Europa.
Attached is my paper on it from my website (yea I gotta work some more on that too).
On cross country if you land at an airport with people, it is very nice to see if someone has a tire change kit in their car or pickup truck as that is all you need.
Even a breaker bar to insert into the axle is simple do.  A small car or truck scissors jack is always around.  So, I don't carry a thing for a tire change on a trigear.  The nut on the axle is standard aircraft also, so any Aircraft Mechanic has the socket or even offset pliers will do in a pinch.  For those going into small farm strips or remote areas, a hollow steel pipe of sufficient length and a "Ford Wrench" or plumbers spanner, or offset pliers that open to 1.25 inches and such in your tool kit works without too carrying much weight.  Small scissors jacks are in most auto tire change kit, and the tire lug wrench in most larger cars or trucks have a very sturdy tool that can easily jack a Europa.  I think the pipe I use is a galvanized 3/4 inch water or gas pipe from the hardware store that is about 12 - 15 inches long and is more than adequate to jack a fully loaded Europa.  The pipe must be just long enough to go on the jack and insert a couple inches into the axle plus the width of the wheel.  I use the same pipe on my annual inspection to jack, pull the wheel, and simply lower the bare axle on to a couple of padded 4x4s to set the axle on to  while I repack the bearings.
Attached is my paper.
Bud Yerly
Custom Flight Creations
In case you've never seen one, this is a short handle plumbers spanner.  They are usually aluminum and quite light:
<![endif]--><![if !vml]>[img]cid:image001.png(at)01DA098B.C92B1940[/img]<![endif]><![endif]-->
 Filesize:  51.25 KB
 Viewed:  7300 Time(s)
Tire_change_of_a_Europa.docx
 Filename:  Tire_change_of_a_Europa.docx
 Filesize:  1004.46 KB
 Downloaded:  577 Time(s)
JonathanMilbank
PostPosted: Sat Oct 28, 2023 10:31 am    Post subject: Re: Europa tri-gear wheel change Reply with quote
Thanks everybody. This confirms what I have been doing i.e. inserting a snug fitting round bar into the axle with enough length to jack the wheel off the ground and also to slide the wheel along the bar.
I was only asking in case someone has a different method. The method using a U-clamp is making me think too.
DuaneFamly
PostPosted: Sat Oct 28, 2023 12:58 pm    Post subject: Europa tri-gear wheel change Reply with quote
Very nice!
[url=Sent from the all new AOL app for iOS]Sent from the all new AOL app for iOS[/url]
On Saturday, October 28, 2023, 7:45 AM, Bud Yerly <budyerly(at)msn.com> wrote:[quote]
Bud Yerly
[img]cid:cGJNeN9h4bntclXd1Ql4[/img]
 Filesize:  51.25 KB
 Viewed:  7286 Time(s)
Mike Duane
JonathanMilbank
PostPosted: Mon Oct 30, 2023 2:39 am    Post subject: Re: Europa tri-gear wheel change Reply with quote
Just a word of caution to anyone new to the Europa tri-gear and changing a wheel or repairing a tire for the first time. When jacking up on the piece of metal rod or breaker bar which you've inserted into the hollow axle, place the scissor/trolley jack a couple of inches inboard from the end. I have seen the jack slip slightly toward the outboard end of the metal rod while being raised.
While the wheel is being jacked up, it is likely that once the tire is off the ground, the bar will not be horizontal and therefore won't be at a right angle to the jack. The higher that the jack is raised, the greater the potential for it to slip sideways and drop the aircraft.
Therefore I have a block of concrete or wood ready to slip under the undercarriage leg where the brake caliper attaches, as soon as I've loosened the brake disc and wheel and moved them out of the way. Only after the flange for attaching the caliper is resting on the block, do I breathe easier.
