Panel sketching
phillik747
PostPosted: Mon Oct 16, 2023 7:20 am    Post subject: Panel sketching Reply with quote
Hello all,
I have been trying to come up with different ideas for a panel layout and which vendor to go with. Instead of printing out all the avionics to size then place on the actual panel (which I will do later), I made a sketch of the panel to write on. This allowed me to keep different ideas on paper to reference later.
Attached are the panels for a mono or TG for you to print and draft with.
Europa_Panel_tg.pdf
 Filename:  Europa_Panel_tg.pdf
 Filesize:  810.52 KB
 Downloaded:  525 Time(s)
Europa_Panel_mono.pdf
 Filename:  Europa_Panel_mono.pdf
 Filesize:  832.1 KB
 Downloaded:  534 Time(s)
Kyle
Europa Tri-gear (under construction)
