Motor reversing circuit for trim servo motor using automoti
charlesdavis(at)iuncapped
PostPosted: Sat Aug 05, 2023 9:31 am    Post subject: Motor reversing circuit for trim servo motor using automoti Reply with quote
Bob, could you share some details on the actuator and how you
implemented the fit, please .... I need to achieve something similar to
this for a Whisper TMG.
Thanks, Charles
On 31/07/23 07:12 pm, Bob Verwey wrote:
I have converted a Luscombe manual trim to work with a linear actuator. 12v.
Momentary rocker switch on control stick.
While the internet abounds with circuit offerings, I am aware of
potential "noise" elements and there are probably a few best practices
to adhere to.
Any circuit suggestions appreciated.
Best...
Bob V
bob.verwey(at)gmail.com
PostPosted: Mon Aug 07, 2023 9:21 am    Post subject: Motor reversing circuit for trim servo motor using automoti Reply with quote
This is a well tested solution on LSA airplanes in our part of the world.
Small trimtab makes it unlikely that a runaway event or mechanical disconnect will lead to catastrophic failure. Furthermore, these airplanes are for day VFR use only.
The unit is a simple 2 wire system and robust, with internal travel limit switches.
[img]cid:ii_ll14yjzy0[/img]
On Mon, 7 Aug 2023 at 01:55, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
At 12:31 PM 8/5/2023, you wrote:
--> AeroElectric-List message posted by: Charles Davis <charlesdavis(at)iuncapped.co.za (charlesdavis(at)iuncapped.co.za)>
Bob, could you share some details on the actuator and how you implemented the fit, please .... I need to achieve something similar to this for a Whisper TMG.
Thanks, Charles
 I've not been involved in crafting such an
 installation in a light plane. I have worked
 on controls and components for trim actuator
 systems from Lear 55 down thru numerous light planes.
 I've had failure analysis tasks on several
 trim systems and I'm familiar with some
 of the requirements and risks.
 When I read that someone is considering or
 has accomplished a modification to a design
 with a demonstrated or certified history,
 little red flags pop up. Just be sure that
 the proposed system won't cut the stabilizer
 or tabs loose to flop in the breeze.
                  (o o)
   ===========o00o=(_)=o00o=========
   < Go ahead, make my day . . .   >
   < show me where I'm wrong.      >
   In the interest of creative evolution
   of the-best-we-know-how-to-do based
   on physics and good practice.
Best Regards,Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
 Filesize:  1.6 MB
 Viewed:  2219 Time(s)
PostPosted: Mon Aug 07, 2023 3:43 pm    Post subject: Re: Motor reversing circuit for trim servo motor using auto Reply with quote
Here is the website for the linear actuator pictured above by Bob Verwey.
https://www.linact.co.za/lite-duty-linear-actuators/#Micro_N2
Joe Gores
