wiring schematic RV-10 IFR purpose HB-YKP
werner schneider
PostPosted: Wed May 31, 2023 2:14 pm    Post subject: wiring schematic RV-10 IFR purpose HB-YKP Reply with quote
Dear all,
here my 1st attempt, the load analysis is mostly based on manufacturer loads yet and I did not yet fill all the columns. Distribution is based on the mission IFR, however it has more on the essential bus then needed, due to the limitation of 20 slots on the main fuse board.
I have a different approach for the Aux alternator as I had already the SB1B controller, so by standard the Aux alternator would be switched on together with the main alternator.
one thing I'm not 100% certain if the Aux alternator switch/bus-sense is on the right bus, as I would need to have the alternate feed switch on in case I would switch of the main bus or the Aux alternator would shut down (maybe the bat bus is the right location?)
Thanks for review an comments/questions.
Cheers Werner
my_electrical-load-analysis.pdf
load analysis
 Filename:  my_electrical-load-analysis.pdf
 Filesize:  22.04 KB
 Downloaded:  648 Time(s)
Z101B-HB-YPK.pdf
Bus diagram
 Filename:  Z101B-HB-YPK.pdf
 Filesize:  201.72 KB
 Downloaded:  358 Time(s)
