Z1 Question
mike(at)vision499.com
PostPosted: Thu May 11, 2023 6:50 am    Post subject: Z1 Question Reply with quote
I have mostly used Z1 with the B&C Alternator controller. I have the “BUS” wire connected to terminal 6 protected with a 5 amp breaker on the panel as illustrated.
I am now preparing the POH and would like to know under what scenarios I would want to “PULL” the breaker.
Mike
Mike Pienaar
mike(at)vision499.com (ike(at)vision499.com)
Mike cell: +1 250-885-0554
1-1100 Tulip Ave, Victoria, BC, V8Z 0A2
Peter(at)sportingaero.com
PostPosted: Fri May 12, 2023 2:24 am    Post subject: Z1 Question Reply with quote
I would suggest none while you are flying.
If you need to turn off the electrics you would use the master switch.
During maintenance to depower the alternator field.
Peter
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of mike(at)vision499.com
Sent: Thursday, May 11, 2023 3:48 PM
Subject: Z1 Question
Mike
Mike Pienaar
mikepienaar09(at)gmail.co
PostPosted: Fri May 12, 2023 8:51 am    Post subject: Z1 Question Reply with quote
Thank you very much, why would I want to depower the alternator field?
Mike
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Peter Pengilly
Sent: May 12, 2023 3:24 AM
Subject: RE: Z1 Question
Peter
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> On Behalf Of mike(at)vision499.com (mike(at)vision499.com)
Mike
Mike Pienaar
email(at)jaredyates.com
PostPosted: Fri May 12, 2023 9:37 am    Post subject: Z1 Question Reply with quote
It will run down your battery and make the alternator very warm during extended master-on/engine-off situations.
On Fri, May 12, 2023 at 12:55 PM <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> wrote:
Mike
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> On Behalf Of Peter Pengilly
Peter
Mike
Mike Pienaar
mike(at)vision499.com (ike(at)vision499.com)[u][/u]
endspeed(at)yahoo.com
PostPosted: Fri May 12, 2023 9:43 am    Post subject: Z1 Question Reply with quote
Mike, If you had an external power transient (lightning strike) it is possible that in order to regain alternator output, you might have to reset the alternator field breaker.
On May 12, 2023, at 13:00, mikepienaar09(at)gmail.com wrote:
(at)font-face { font-family: Helvetica; } (at)font-face { font-family: "Cambria Math"; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: "Comic Sans MS"; } p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm; font-size: 11pt; font-family: Calibri, sans-serif; } a:link, span.MsoHyperlink { color: rgb(5, 99, 193); text-decoration: underline; } span.EmailStyle20 { font-family: Calibri, sans-serif; color: windowtext; } .MsoChpDefault { font-size: 10pt; } (at)page WordSection1 { size: 612pt 792pt; margin: 72pt; } div.WordSection1 { page: WordSection1; } <![endif]--> <![endif]-->
Mike
Peter
Mike
Mike Pienaar
PostPosted: Fri May 12, 2023 11:19 am    Post subject: Z1 Question Reply with quote
Thanks very muchThat is what I was looking for
 Keep well
Mike
On Fri., May 12, 2023, 10:40 a.m. Jared Yates, <email(at)jaredyates.com (email(at)jaredyates.com)> wrote:
Mike
Peter
Mike
Mike Pienaar
