Europa-List Digest: 6 Msgs - 04/24/23
nicolaandjohn(at)talktalk
PostPosted: Mon Apr 24, 2023 10:40 pm    Post subject: Europa-List Digest: 6 Msgs - 04/24/23 Reply with quote
Please change this email address to:
Johnwt1964(at)gmail.com
Thank you
Sent from my Galaxy
-------- Original message --------
From: Europa-List Digest Server <europa-list(at)matronics.com>
Date: 25/04/2023 07:35 (GMT+00:00)
To: Europa-List Digest List <europa-list-digest(at)matronics.com>
Subject: Europa-List Digest: 6 Msgs - 04/24/23
Today's complete Europa-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2023-04-24&Archive=Europa
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2023-04-24&Archive=Europa
                           Europa-List Digest Archive
                     Total Messages Posted Mon 04/24/23: 6
Today's Message Index:
     1. 01:56 AM - Re: Re: The Obsidian File - Mono Wheel Fairing  (Pete)
     2. 03:08 AM - Re: The Obsidian File - Mono Wheel Fairing  (Area-51)
     3. 03:08 AM - Re: The Obsidian File - Mono Wheel Fairing  (Area-51)
     4. 05:12 PM - The Obsidian Files - Doorly Departed  (Area-51)
     5. 05:47 PM - Re: The Obsidian Files - Doorly Departed  (William Daniell)
     6. 08:02 PM - Re: The Obsidian Files - Doorly Departed  (Area-51)
________________________________  Message 1  _____________________________________
Time: 01:56:02 AM PST US
Subject: Re: Europa-List: Re: The Obsidian File - Mono Wheel Fairing
Fence details?
On Apr 24, 2023, at 12:15 AM, Area-51 <goldsteinindustrial(at)gmail.com> wrote:
Brunch has turned into lunch..
The fence concept has provided value by reducing the acoustic pressure pulses
to almost zero and assisting in keeping trailing turbulence tighter within the
fuselage centerline... Drag and Lift gains and losses were not anything worth
noting; mostly "shut that noise up"; advantages being greatest using the semi
enclosed fairing option, however both semi enclosed and standard setups nullified
the trailing pressure pulse effects... two thumbs up on this one.
http://forums.matronics.com/viewtopic.php?p=510684#510684
________________________________  Message 2  _____________________________________
Time: 03:08:12 AM PST US
Subject: Europa-List: Re: The Obsidian File - Mono Wheel Fairing
Lunch has now turned into dinner.. there was a brief hiatus in the weather where
the sun came out and a bunch of bananas were lopped from the tree and many hands
cut off; of bananas, not apes...
So just for entertainment and curiosity the fence concept was extended further
to a more aft limit.. that worked favourably; so the concept was developed into
a rib extending to around 1m short of the stern. And that appears to also work
favourably toward keeping air flowing neatly and quietly downstream to the
undercarriage. A secondary affect if shaped with foam and glassed over would be
added rigidity of the belly skin and less tendency for panel drumming.
Peter the fence is just a 3.00mm piece of flat plate running from the lower engine
cowl side face rearward; a block of triangular shaped foam glued to the skin
would also work for a temporary trial... ending it just forward of the fuel
drain vents will function well; the fence height used in tests is 64.0mm.
http://forums.matronics.com/viewtopic.php?p=510686#510686
http://forums.matronics.com//files/5c0d4f52_ccdd_4d1f_8991_350b77ff7b8a_102.jpeg
http://forums.matronics.com//files/98ecba07_4c10_4089_84da_feb258ca2f8c_594.jpeg
http://forums.matronics.com//files/1b63a2e1_48ca_45ef_bb09_30c364045798_129.jpeg
http://forums.matronics.com//files/ed982eee_14f5_49fb_8c7a_4ee40a335cb3_159.jpeg
http://forums.matronics.com//files/53c98d9e_97df_42b8_902c_eafa74a11a74_201.jpeg
http://forums.matronics.com//files/c6e645a0_3648_422d_84a1_3e917d0a2aff_142.jpeg
http://forums.matronics.com//files/454164c8_30b1_4232_bdeb_b879e509c25a_414.jpeg
http://forums.matronics.com//files/262db7ea_dbc7_4de8_962d_22427748f1dd_171.jpeg
________________________________  Message 3  _____________________________________
Time: 03:08:14 AM PST US
http://forums.matronics.com/viewtopic.php?p=510687#510687
________________________________  Message 4  _____________________________________
Time: 05:12:39 PM PST US
Subject: Europa-List: The Obsidian Files - Doorly Departed
Have been looking forward to this one...
The outcome was disappointing.. was expecting wind in the cockpit; and thats all
that really happened...
Drag went up 25kg at 100kt for a twin door departation and 17kg for a single door
scenario... on both events the wind came into the cockpit!! It swirled around
and down into the footwells and rear luggage wells, where it swirled around
some more before shooting out straight up at the human head like an upper cut
from both front an rear directions before flying out and over the rear of the
door frame... Anything left loose in the cockpit is getting sucked up and is
going out an opening after slapping the occupants in the head.. for a dual door
situation the swirl remains left and right sided; leaning one's head to the
centre and back may find a pool of calmness... A single door situation is more
exciting; the swirl comes up to the opening on a diagonal from the opposite side
hitting the human closest to the opening in the head from the front and rear
on the way out; anything left loose in the luggage well, shelf, footwell is
going out the opening after slapping the occupant in the face; the occupant can
be human dog or cat... a small dog like chihuahua is probably going out the
opening... a loose ipad; out the opening... and that's about it..
The aircraft is flyable without one or both doors but it won't be very pleasant
at all with 25-30kt winds swirling around like tornado....
Maybe some deflectors will improve a doorless situation...
http://forums.matronics.com/viewtopic.php?p=510689#510689
http://forums.matronics.com//files/29147814_5dc4_4c17_8ddf_9be761ece51c_137.jpeg
http://forums.matronics.com//files/c3da4c4f_6974_4ff6_b83c_8cb5c4011888_123.jpeg
http://forums.matronics.com//files/073d78e2_bbb3_4d31_a543_0c335e5ab1f7_419.jpeg
http://forums.matronics.com//files/b0ccd426_c7fb_43fd_a0ac_b161dbac545c_664.jpeg
http://forums.matronics.com//files/d941b467_be32_4bb9_b0e8_6c55ccb57f5a_172.jpeg
http://forums.matronics.com//files/6e09ada6_17ba_492d_aa23_e0e7e3013f35_163.jpeg
http://forums.matronics.com//files/dc3b3168_f943_4603_9941_461124ceb381_152.jpeg
http://forums.matronics.com//files/b2c6221a_6d0b_4477_8fef_9572aed30447_202.jpeg
http://forums.matronics.com//files/b2020f6f_ca5f_45ae_b7c3_0598c6c5849b_801.jpeg
________________________________  Message 5  _____________________________________
Time: 05:47:02 PM PST US
From: William Daniell <wdaniell.longport(at)gmail.com>
Subject: Re: Europa-List: The Obsidian Files - Doorly Departed
Interestingly my colombian  friend whose door opened in flight reported the
very same thing.   His pax grabbed and partially closed the door.
He was worried that the cover would exit the door and wrap round the
tail...In the attempt to catch the cover  his passenger let go of the door
handle and away went the door.
They did catch the cover tho.
William Daniell
+1 786 878 0246
On Mon, Apr 24, 2023, 20:14 Area-51 <goldsteinindustrial(at)gmail.com> wrote:
thats all that really happened... =F0=9F=A4=B7=F0=9F=8F=BC=8D=99
=82=EF=B8=8F
single door scenario... on both events the wind came into the cockpit!! I
t
swirled around and down into the footwells and rear luggage wells, where
it
swirled around some more before shooting out straight up at the human hea
d
like an upper cut from both front an rear directions before flying out an
d
over the rear of the door frame... Anything left loose in the cockpit is
getting sucked up and is going out an opening after slapping the occupant
s
in the head.. for a dual door situation the swirl remains left and right
sided; leaning one's head to the centre and back may find a pool of
calmness... A single door situation is more exciting; the swirl comes up
to
the opening on a diagonal from the opposite side hitting the human closes
t
to the opening in the head from the front and rear on the way out; anythi
ng
left loose in the luggage well, shelf, footwell is going out the opening
after slapping the occupant i!
  n the face; the occupant can be human dog or cat... a small dog like
chihuahua is probably going out the opening... a loose ipad; out the
pleasant at all with 25-30kt winds swirling around like tornado....
Maybe some deflectors will improve a doorless situation... =F0=9F=A4=94
________________________________  Message 6  _____________________________________
Time: 08:02:27 PM PST US
Subject: Europa-List: Re: The Obsidian Files - Doorly Departed
Thanks for the input William... Its amazing how the computer can mathematically
estimate actuals. Something like a cover could wrap around the head very quickly.
I'm not totally finished on this one yet and want to look at how the complete airframe
responds in the 3 axis environment when a door departs.
All analysis so far are just preliminary static tests to identify generated sound
levels and fluid reaction around the component body.
http://forums.matronics.com/viewtopic.php?p=510691#510691
_-============================================================
_-=          - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?Europa-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
_-=  Thank you for your generous support!
_-=                              -Matt Dralle, List Admin.
_-=   --> https://matronics.com/contribution
