Auxiliary- Longranger Fuel Tank ARM
tonyvaccarella
PostPosted: Sat Apr 22, 2023 11:29 pm    Post subject: Auxiliary- Longranger Fuel Tank ARM Reply with quote
Hi fine Europa people,
Soon Ill be having my W&B done for my Europa XS. The kit I purchased came with the auxiliary Longranger fuel tank. Although Ive looked, I cant find an official ARM from the datum for this tank. The aircraft fuel tank ARM is 76" while the baggage area is listed as 88". For those of you who have this tank installed, would you mind sharing the ARM utilised for W&B calculations?
Many thanks for your help.
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
h&jeuropa
PostPosted: Sun Apr 23, 2023 2:52 am    Post subject: Re: Auxiliary- Longranger Fuel Tank ARM Reply with quote
Tony,
We use 85 inches.
Jim & Heather
davidjoyce(at)doctors.org
PostPosted: Sun Apr 23, 2023 3:12 am    Post subject: Auxiliary- Longranger Fuel Tank ARM Reply with quote
Tony, I just split the difference, ending up with82” but you can easily enough measure from the cowling joggle (the zero ref point) to the centre of the tank. Regards, David Joyce, ex GXSDJ
On 2023-04-23 08:29, tonyvaccarella wrote:
--> Europa-List message posted by: "tonyvaccarella" <tony(at)weimagine.com.au (tony(at)weimagine.com.au)>Hi fine Europa people,Soon Ill be having my W&B done for my Europa XS. The kit I purchased came with the auxiliary Longranger fuel tank. Although Ive looked, I cant find an official ARM from the datum for this tank. The aircraft fuel tank ARM is 76" while the baggage area is listed as 88". For those of you who have this tank installed, would you mind sharing the ARM utilised for W&B calculations?Many thanks for your help.Tony--------Tony VaccarellaMascot NSW 2020Sydney AustraliaRead this topic online here:http://forums.matronics.com/viewtopic.php?p=510671#510671et="_blank" rel="noopener noreferrer">http://forums.matronics.com[/url]
tonyvaccarella
PostPosted: Wed Apr 26, 2023 3:43 am    Post subject: Re: Auxiliary- Longranger Fuel Tank ARM Reply with quote
Many thanks for your input. Just FYI I measured the actual ARM last weekend and it worked out to by 85.5 inches.
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
