smgates
Joined: 13 Apr 2019 Posts: 13 Location: Perth, Australia
Posted: Wed Apr 05, 2023 11:18 pm Post subject: Kolb-List Digest: 2 Msgs - 04/05/23 |
Hi Jay,
I'm using a 503 on my Firestar II with 1/4" ID hose and it seems just fine
over about 17 hrs flight time so far.
I got rid of the bulb because I was concerned about the very problem you
mentioned, and put in an automotive electric pulse pump, which I mostly only
use to prime/start the engine because the Rotax pulse pump is adequate for
normal flight in my experience so far - also makes a much tidier
installation not having the bulb accessible to prime.
Good luck with it,
Steve
702.54 KB |
11149 Time(s) |
_________________ Gator |
