Tank repair options
wdaniell.longport(at)gmai
PostPosted: Wed Mar 01, 2023 6:31 am    Post subject: Tank repair options Reply with quote
https://tbbonding.com/glue-polyethylene/
I came across this looking for adhesive for a kayak.  thought it might be of interest.  It specifically mentions tank repair.
Will
William Daniell
LONGPORT
+1 786 878 0246
dmac7
PostPosted: Fri Mar 03, 2023 9:51 am    Post subject: Re: Tank repair options Reply with quote
That's very interesting, if what they say is true replacing cracked fuel tanks could be a thing of the past. Thx William
PostPosted: Fri Mar 03, 2023 2:22 pm    Post subject: Tank repair options Reply with quote
I have no first hand experience of this ....just to clarify.
But i might get some to see how it works.
Will
William Daniell
+1 786 878 0246
On Fri, Mar 3, 2023, 10:53 dmac7 <dmac7(at)outlook.com (dmac7(at)outlook.com)> wrote:
--> Europa-List message posted by: "dmac7" <dmac7(at)outlook.com (dmac7(at)outlook.com)>
http://forums.matronics.com/viewtopic.php?p=510333#510333
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
h&jeuropa
PostPosted: Fri Mar 10, 2023 7:39 am    Post subject: Re: Tank repair options Reply with quote
Brad Shafer is having problems posting here, so I am forwarding his Facebook posts.
Like many others, I woke up to gas on the floor and a crack in the tank.
Mine was low on the saddle. I liked what Dave Disney had done so I drained the tank and created an opening in the top. With the ability to inspect the inside of the tank (which is a very nice option to have!), I found another narrow crack in the bottom corner that must have been there for awhile.
Given the placement of the cracks, I couldn't find a way to gain access with a heat gun so I needed to find another option. I found this (https://tbbonding.com/) as an option to patch poly tanks. I talked with them and felt good about trying. I like the idea that the patch is flexible and will expand with the tank.
Jim Butcher
Worst case, it doesn't work and I do the full tank replacement. The bonding process was straight forward and fairly easy with access to the inside of the tank. So far it is holding well after 6 months but I'm going to do some more testing to make sure.
 Filesize:  136.45 KB
 Viewed:  3821 Time(s)
 Filesize:  867.07 KB
 Filesize:  945.26 KB
