Beringer wheel & brake
rehn(at)rockisland.com
PostPosted: Tue Feb 28, 2023 1:50 pm    Post subject: Beringer wheel & brake Reply with quote
Hello All
I’m considering the Beringer wheel and looking for experience of others with Beringer. I’ve had 3 pinch flats on my mono and will get the better tubes and higher inflation to help prevent future failure but still concerned about being stranded on a strip.
Perhaps the tubeless tire Beringer will work better and still allow for less tire pressure and help with landing. Also the added breaking power.
Thanks for any input and advice!
Jerry
914 Mono XS
davidjoyce(at)doctors.org
PostPosted: Tue Feb 28, 2023 2:55 pm    Post subject: Beringer wheel & brake Reply with quote
Jerry, I was delighted with how well it worked for me. Clearly better braking and lighter. My only cabeat is that it is possibly a mistake to fit it with the bicycle brake style lever on the P1 column. You may come to want to be able to brake from P2 position somewhere down the line, so I recommend a lever system in the conventional Europa position. David Joyce, formerly GXSDJ
On 2023-02-28 21:49, Jerry Rehn wrote:
--> Europa-List message posted by: Jerry Rehn <rehn(at)rockisland.com (rehn(at)rockisland.com)>Hello AllI&rsquo;m considering the Beringer wheel and looking for experience of others with Beringer. I&rsquo;ve had 3 pinch flats on my mono and will get the better tubes and higher inflation to help prevent future failure but still concerned about being stranded on a strip. Perhaps the tubeless tire Beringer will work better and still allow for less tire pressure and help with landing. Also the added breaking power.Thanks for any input and advic.matronics.com/Navigator?Europa-List" target="_blank" rel="noopener n href="http://forums.matronics.com" target="_blank" rel="noopener nortarget="_blank" rel="noopener noreferrer">http://wiki.matronics.comnbsp; -Matt Dm/contribution" target="_blank" rel="noopener noreferrer">https://matro=====================
