farmrjohn
Posted: Wed Feb 08, 2023 6:42 pm Post subject: Post lamp wire connection method |
I have searched unsuccessfully on how to connect post lamps or LEDs that have pig tail wires attached and that mount from the front of a panel through a 1/4" mounting hole. If it is ever necessary to remove either the fixture itself of the panel how does one "disconnect" the wires? Would a bullet connector like those used on motorcyles be appropriate? http://www.cycleterminal.com/4mm-Bullet-Terminal-Connector-setx10.jpg Thanks, John
Joined: 28 Mar 2008 Posts: 1962 Location: Riley TWP Michigan
Posted: Wed Feb 08, 2023 7:40 pm Post subject: Re: Post lamp wire connection method |
How about D-Sub pins and sockets? If LEDs, then they are unlikely to need
disconnecting. Don't use connectors. If not installed, they can't fail.
_________________ Joe Gores |
farmrjohn
Posted: Thu Feb 09, 2023 8:58 am Post subject: Re: Post lamp wire connection method |
| user9253 wrote: | How about D-Sub pins and sockets? If LEDs, then they are unlikely to need
disconnecting. Don't use connectors. If not installed, they can't fail. |
I had thought about those per previous research. For a permanent connection I would just use a butt splice. I'm not as concerned about failure of the light but will need to occasionally remove the panel they are mounted on. It could be challenging to get a heat gun in the area to shrink the heat shrink over the pins and sockets as well.
