Replacing copper bar with tefzel wire
jcohen@post.com
PostPosted: Fri Feb 03, 2023 7:47 pm    Post subject: Replacing copper bar with tefzel wire Reply with quote
I am building a Vans RV7 , IO360, Z101, using B&C master and starter contactors, and an EarthX ETX 900 battery. I can’t easily use the Vans design solution of 0.125” thick copper bar, about 3” long x 0.5” wide, to connect the master solenoid to the starter solenoid, due to physical placement on my firewall and the stud orientation on the B&C starter contactor. So I want to use an insulated wire instead of the bar, maybe only 4” or so.
From old posts on vansAirforce.net forum, the current here is estimated to be up to 320 amps for short periods while cranking the starter. Is that correct? What gauge tefzel wire should I use to maintain the functionality and safety of the copper bar?
Jeff
PostPosted: Sat Feb 04, 2023 7:03 pm    Post subject: Re: Replacing copper bar with tefzel wire Reply with quote
Use the same size wire that connects the starter contactor to the starter motor.
4AWG is used on some of Bob's diagrams.
Joe Gores
PostPosted: Sun Feb 05, 2023 12:55 pm    Post subject: Replacing copper bar with tefzel wire Reply with quote
At 09:47 PM 2/3/2023, you wrote:
--> AeroElectric-List message posted by: "jcohen(at)post.com" <jcohen(at)post.com>
I'm skeptical of that current number . . . nonetheless,
a 4AWG piece of wire would be just fine. If you don't yet
have the wire, get a chunk of welding cable from a local
welding supplies shop. MUCH more flexible and installer
friendly. Be gentle on yourself too . . . don't make the
jumper run a tight, straight line between studs. Make
it a leisurely hop between mounting locations so that
you can exploit that flexibility; i.e. a 6" piece
of wire is about right for connecting studs 4" apart.
out of that stuff?"
jcohen@post.com
PostPosted: Thu Feb 09, 2023 3:35 pm    Post subject: Re: Replacing copper bar with tefzel wire Reply with quote
Thank you for your comments. Welding cable it is!
Jeff
