912ULS classic radiator cap pressure?
peterz(at)zutrasoft.com
PostPosted: Tue Jan 17, 2023 5:07 am    Post subject: 912ULS classic radiator cap pressure? Reply with quote
Indeed the triumph cap p/n T2108005 does indeed fit, with very close, but not exact dimensions to the stocker, and tested to release around 1.1bar using an inexpensive tester.
The housing is of thinner material, but still adequate. The outer seal is actually floating on a “bearing” eliminating the sliding friction when installing compared to the original. Overall it appears to be higher quality.
Btw, when tested, my original cap was found to be leaking - so i was running at ambiant pressure explaining my blow-off.
Cheers and thanks for the tip!
PeteZ
On Jan 3, 2023, at 3:25 AM, Alan Burrill <alanb(at)dpy01.co.uk> wrote:
Service bulletins sb-912-043-r2 and sb-914-029-r3 issued November 2006 uplifted the radiator pressure cap to 1.2bar.
It also has the ROTAX part no for the replacement.
I owned a Triumph Sprint motorcycle and found the radiator cap was the same size and pressure setting although whether you fit that is down to you.
Alan
> On 3 Jan 2023, at 00:05, JonathanMilbank <jdmilbank(at)yahoo.co.uk> wrote:
> Many, many years ago it was advised to change from 0.9 to 1.2 bar. A friend gave me a spare, which he bought from an online motorcycle shop, which I think was intended for a water cooled Triumph? motorbike. Anyway it's smaller than those found on car radiators.
> http://forums.matronics.com/viewtopic.php?p=509842#509842
 Filesize:  44.41 KB
 Viewed:  1899 Time(s)
 Filesize:  43.92 KB
 Filesize:  45.79 KB
