Nylon #2 Phillips Screw Driver Bits...?
Site Admin
PostPosted: Tue Jan 03, 2023 4:09 pm    Post subject: Nylon #2 Phillips Screw Driver Bits...? Reply with quote
Hi Fellow RV Builders,
After 12 years since the test-flight, I finally got my RV-8 painted! Cascade Customs and Design in Bend Oregon did an outrageously awesome job! She is a beaut!
I had them put all new cad-plated screw hardware back in after painting. I decided that gold hardware against the red, just didn’t look as finished as I’d hoped. So, I counted all the screws and had them paint the appropriate number of screws plus some spares with the intent of swapping all the unpainted with painted.
The problem is the standard steel Phillips screw driver bits seems to chip the paint in the screw pretty easily.
I thought that I’ve seen #2 Phillips NYLON screw driver tips somewhere a while back? But I can’t seem to find them now? Does anyone have a lead on Nylon #2 bits?
RV-8 N998RV “Ruby Vixen”
https://youtu.be/57ihMKzMojE
 Filesize:  52.15 KB
 Viewed:  15176 Time(s)
 Filesize:  24.99 KB
