Master Relay current draw...
andymeyer
PostPosted: Sun Dec 25, 2022 1:34 pm    Post subject: Master Relay current draw... Reply with quote
Old master relay in my Long EZ - it's pulling about 2.3 amps - just the relay itself - sounds like it's way high. Any recommendations for a low current replacement?
What's the typical draw for one of these and what would cause the high draw? (I don't have the model of relay in front of me, but it appears to be a fairly standard relay) 12V system...
Do these relays have a pull-in and a holding circuit, or are they just a single pull-in coil that is energized the entire time the relay is closed?
Ceengland
PostPosted: Sun Dec 25, 2022 2:37 pm    Post subject: Master Relay current draw... Reply with quote
Might be a little high; you can download a datasheet from Spruce here:
https://www.aircraftspruce.com/catalog/elpages/masterrelay.php
Any chance the builder installed a starter relay in the master slot?
Starter relays typically have higher coil current to engage quicker, etc.
You can spend a bunch more money on a solid state model, but I wouldn't
consider it good value.
Charlie
www.avast.com
Charlie
PostPosted: Sun Dec 25, 2022 8:38 pm    Post subject: Re: Master Relay current draw... Reply with quote
According to this post:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=117069337?KEYS=.6_amps_warm?LISTNAME=AeroElectric?HITNUMBER=3?SERIAL=18371020034?SHOWBUTTONS=YES
A Cole-Hersee contactor draws 1 amp cold and drops to about 0.6 amps warm.
Current is determined by the load, the contactor coil is this case.
Joe Gores
PostPosted: Sun Dec 25, 2022 8:48 pm    Post subject: Re: Master Relay current draw... Reply with quote
Bob's Contactor duty cycle controller
Contactor_Duty-Cycle_Controller.pdf
 Filename:  Contactor_Duty-Cycle_Controller.pdf
 Filesize:  55.27 KB
 Downloaded:  302 Time(s)
Joe Gores
PostPosted: Sun Dec 25, 2022 10:04 pm    Post subject: Master Relay current draw... Reply with quote
At 03:34 PM 12/25/2022, you wrote:
--> AeroElectric-List message posted by: "andymeyer" <meyerkc135(at)gmail.com>
Yes, that IS waayyy too high for a battery contactor.
It's been suggested that you may have inadvertently
installed an intermittant duty contactor. Here's
one option for a more appropriate device.
https://tinyurl.com/y9nbkhgo
See:
http://aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_1.jpg
http://aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_2.jpg
out of that stuff?"
bob.verwey(at)gmail.com
PostPosted: Sun Dec 25, 2022 10:11 pm    Post subject: Master Relay current draw... Reply with quote
Andy the " homebuilt" master relay I purchased from Spruce recently  does not even draw 1 amp. While working on the aircraft late one afternoon I forgot to turn it off...the next morning it was warm to the touch but the battery voltage was still in the normal range. On my old Bonanza I noticed that the starter contactor drew higher current than the master contactor, also they are the older style devices..
Best...Bob
On 26 Dec 2022 00:39, "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
> --> AeroElectric-List message posted by: "andymeyer" <meyerkc135(at)gmail.com (meyerkc135(at)gmail.com)>
Charlie
www.avast.com
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
andymeyer
PostPosted: Tue Dec 27, 2022 5:21 am    Post subject: Re: Master Relay current draw... Reply with quote
Thanks! Getting a new one on the way ASAP.
