The Obsidian File
Area-51
PostPosted: Thu Nov 24, 2022 7:32 am    Post subject: The Obsidian File Reply with quote
Black Op's on Baker Build 181 have not been secretly happening for the past 18 months. Rumours, just rumours... nothing to see here... just some routine wing flange dressing on a computer that does not exist...
 Filesize:  41.99 KB
 Viewed:  4633 Time(s)
 Filesize:  85.27 KB
 Filesize:  48.64 KB
 Filesize:  52.54 KB
 Filesize:  37.42 KB
 Filesize:  73.32 KB
 Filesize:  52.07 KB
 Viewed:  4630 Time(s)
dmac7
PostPosted: Fri Nov 25, 2022 7:38 am    Post subject: Re: The Obsidian File Reply with quote
Ahh the fabulous Baker build I have heard of her! Nice details, Paul Lipps would have approved of your vent scoops, he once wrote of scoops vs NASA scoops in Kite planes magazine. Clean looking wing junction, overall nice images thx.
Area-51
PostPosted: Tue Nov 29, 2022 12:13 pm    Post subject: Re: The Obsidian File Reply with quote
Empennage is finally done; ended up rebuilding the entire section due to annoying original surface issues, and now it is better than ever.
Apart for a couple of inspection hatches, muffler, and main wheel to be added over the next few days the model is now good enough and complete for a multitude of uses. Some final artifact removal and fillet tuning on the rudder and thats Baker Built #181 done n dusted.
Very happy with the result! Viva le Europa...
 Filesize:  40.41 KB
 Viewed:  4542 Time(s)
 Filesize:  42.36 KB
 Filesize:  54.87 KB
 Filesize:  47.27 KB
Area-51
PostPosted: Wed Nov 30, 2022 7:08 am    Post subject: Re: The Obsidian File Reply with quote
Today the very back end of Baker Build 181 received some final tweaking around the rudder foil belly and top fillet edges... The inspection plates went in and the tailwheel arm got updated and set in place to match actuals along with the underbelly port for the original factory Classic tail wheel... the day has finished with a digital application of All-U-Need 2pack high build epoxy sealer primer to keep the digital moister out of our perfect digital surfaces.
Tomorrow will set in the factory main wheel into the tyre and see the same for the current tail wheel.
And that's it folks for everything that is visual; from here on its all just unseen under the skin mechanical stuff. We have a complete real world aerodynamic model of a Europa Classic; ready for deep analysis.
Tomorrow will be looking forward to bringing this chapter to completion... the Obsidian File is in review!
 Filesize:  67.5 KB
 Viewed:  4504 Time(s)
 Filesize:  78.37 KB
 Filesize:  84.78 KB
 Filesize:  69.75 KB
 Filesize:  62.77 KB
peterz(at)zutrasoft.com
PostPosted: Wed Nov 30, 2022 7:31 am    Post subject: The Obsidian File Reply with quote
Mucho-Cool!
Eagerly awaiting the analysis! Smile
PeteZ
Classic C-GNPZ
On Wed, Nov 30, 2022 at 10:21 AM Area-51 <goldsteinindustrial(at)gmail.com (goldsteinindustrial(at)gmail.com)> wrote:
--> Europa-List message posted by: "Area-51" <goldsteinindustrial(at)gmail.com (goldsteinindustrial(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=509340#509340
http://forums.matronics.com//files/40ee7598_eeb9_4526_a897_18380257decf_887.jpeg
http://forums.matronics.com//files/fa4fb748_c771_4923_9ead_e2aa20fcc61c_170.jpeg
http://forums.matronics.com//files/aea1f43e_f8ab_4eaa_b17a_67b8f52db01b_173.jpeg
http://forums.matronics.com//files/78879ebc_6f1d_4787_ab4b_2f212ee4640e_805.jpeg
http://forums.matronics.com//files/10bde18e_bdca_495e_834a_6a3fade7b50e_595.jpeg
WIKI -
Area-51
PostPosted: Thu Dec 01, 2022 8:21 am    Post subject: Re: The Obsidian File Reply with quote
Thanks Pete!
An easy day for a change; main wheel, original Classic tail wheel, muffler, and a few renders to check how it all looks... that's a wrap now on all the outside stuff; summer has started...
Time for a little bit of a rest...
 Filesize:  73.72 KB
 Viewed:  4477 Time(s)
 Filesize:  61.72 KB
 Filesize:  83.06 KB
 Filesize:  87.29 KB
 Filesize:  69.59 KB
 Filesize:  47.48 KB
 Filesize:  50.02 KB
 Filesize:  57.81 KB
 Filesize:  57.53 KB
Area-51
PostPosted: Wed Dec 07, 2022 4:21 am    Post subject: Re: The Obsidian File Reply with quote
The aero model is now complete, with individual split control surfaces... so the first point of orientation setup was a dirty side slip... A bit more final detail added to prepare for another round of tests in the digital wind tunnel... no idea what may happen with what is now such a feature rich model. Computer may not be able to handle the crunching of so many components this close to christmas...
 Filesize:  63.37 KB
 Viewed:  4414 Time(s)
