12mm Cylinder Base Jet Nut wrenches
fishmouth500
PostPosted: Sat Oct 29, 2022 1:17 pm    Post subject: 12mm Cylinder Base Jet Nut wrenches Reply with quote
If you fly behind one of Mike Hanshew’s highly-prized M14 engines, you’ll recognize these 12 point ‘Jet Nut’ style cylinder base fasteners he uses, which have a conical base flange.
[img]blob:null/03d551b4-9330-4c2e-9aff-87c2ba9d97b3[/img]
(The stock motor uses 14mm hex nuts with a tab washer securing adjacent pairs.)
TYC has produced a batch of Cylinder Base nut wrenches for these 12 point 12mm Jet Nuts in the style & shape of the original Russian tool.
[img]blob:null/cb77a341-ac14-42f9-9164-f52240077746[/img]
There’s adequate clearance below the cylinder fins for the conical entry on this new wrench to engage a Jet Nut that has been hand-threaded onto the tip of the stud. ( proto wrench shown)
[img]blob:null/4053274a-f5db-4ceb-9168-d6fb03e4dd0e[/img]
Since 2019, more than 100 of TYC’s 14mm  Repro cylinder base nut wrenches have been sold to M14-P owners and maintainers worldwide.
The same lifetime warranty applies to these 12mm Jet Nut wrenches, also made of normalized, heat-treated Chromoly, polished and plated for a lifetime of service.
If you run a Yak maintenance shop, it’s just a matter of time before a customer with one of Mike Hanshew’s motors will fly in for a conditional!
I won’t respond to pricing questions here on the forum so please contact John off-list for more details - thank you!
Theyakcollection(at)gmail.com (Theyakcollection(at)gmail.com)
www.theyakcollection.com
619 933-2571
