Time delay on relay needed
rparigoris
PostPosted: Sun Oct 09, 2022 8:47 pm    Post subject: Time delay on relay needed Reply with quote
Hi Group
I am working on a project where an Arduino is completely unhappy if a 12 volt buzzer is connected to it's 10 amp relay. We tried an awful lot of things including installing another relay and even a separate battery to power the second relay and buzzer. the only thing that works is putting the buzzer on the Arduino relay if you wait one second. Then all is well.
Question:
Can someone point me to a 12 volt coil relay with a approx. 1 second time on delay that can handle 2 amps or more 12VDC? Or how can I delay the 12 volt relay i have from coming on for a second.
Thx.
Ron P.
PostPosted: Mon Oct 10, 2022 6:11 am    Post subject: Re: Time delay on relay needed Reply with quote
Do a Google search for "capacitor time delay circuit".
One of the results of my search turned up this one with a delay of 1.5 seconds.
https://www.arrow.com/en/research-and-events/articles/make-a-simple-capacitor-transistor-timing-circuit
Joe Gores
PostPosted: Mon Oct 10, 2022 6:36 am    Post subject: Time delay on relay needed Reply with quote
At 11:47 PM 10/9/2022, you wrote:
--> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com>
Hi Group
What kind of 'buzzer'? A legacy electro-mechanical device
like we used to build in Cub Scouts?
out of that stuff?"
rparigoris
PostPosted: Mon Oct 10, 2022 11:24 am    Post subject: Re: Time delay on relay needed Reply with quote
Hi Joe Thank you for reply.
Bob:
The Buzzer is an electro mechanical:
https://www.amazon.com/gp/product/B000XBJ3AE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The Arduino is powered by a 12 volt battery going through a converter to make 5 volts for the Arduino. The buzzer is using the 12 volts to operate. We put it on a scope today and saw perturbations of the 5 volts peak to peak of between 10 and 12 volts.
We added transorbs and .1 mF ceramic capacitors across the two parallel buzzers and also a .1 mF ceramic capacitor just before the DC to DC converter. Got peak to peak down to 5 to 6 volts. So far it seems to be working OK.
Ron P.
PostPosted: Tue Oct 11, 2022 8:56 am    Post subject: Time delay on relay needed Reply with quote
Bob:
Ron P.
That style of buzzer is one of many examples
of the classic 'model-T spark coil' physics. What
you're experiencing is conducted noise in the form
of fast-rise time transients generated every
time the points in the buzzer break. This can be
a very 'potent' noise source for some situations.
In fact, legacy DO160 qualification testing used
to include what was commonly called a 'chattering
relay' noise test illustrated here. The "timer"
switch was simply the normally closed contacts
of the test fixture relay, I.e. a 'buzzer'.
The Model-T spark coil was another 'buzzer' where
the buzzer coil shared a core with a bazillion
turns of fine wire where one could exploit very
high voltage transients that would jump the
gap in a spark plug.
A modern exploitation of the same phenomenon
is illustrated in a 'shower of sparks' starting
ignition for an M14 radial engine I crafted for
a YAK driver.
So, getting back you your close encounter of
the unhappy kind, your potential victim is a
micro-controller that runs on 3.3 volts DC.
It doesn't take much of a transient to express
itself as aberrant noise. Data in the uC
lives in a 3 volt, tens of megaHertz world
exceedingly vulnerable to fast rise
transients.
As you've already discovered, suppression of
the buzzer's coil collapse transient mitigates
the problem. If you have access to the buzzer's
coil terminals, it would be interesting to see
if a simple suppression diode would stop the
problem. If not, then some network of external
components is indicated to reduce this potent
noise source from irritating your microcontroller.
out of that stuff?"
 Filesize:  79.24 KB
 Viewed:  4236 Time(s)
 Filesize:  162.07 KB
 Filesize:  173.75 KB
