What did you do with your Europa this week 8/13 - 8/19
h&jeuropa
PostPosted: Sat Aug 13, 2022 11:58 am    Post subject: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
Starting thread for this week.
We'll be cleaning N241BW after last week's trip. We killed a lot of bugs!
Jim
h&jeuropa
PostPosted: Tue Aug 16, 2022 5:28 am    Post subject: Re: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
Flew up to our sailboat in northern Michigan. A beautiful VFR day. On top of a scattered cloud deck a 9500 ft. One of the nicest flights in recent memory.
Jim
dmac7
PostPosted: Thu Aug 18, 2022 7:31 am    Post subject: Re: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
This week I bonded into the stabs 2 BID tube's, they mechanically retain the TP5 & 6 sleeves although they are also reduxed as well.
Thx To Nigel Graham for his genius in developing this mod. The Europa factory incorporated this idea in the NG stabs.
The BID cloth was wetted with redux on advise from Nev.
The stabs which previously fit just horrible ( I didn't build it ) now fit beautifully, 1/8" gaps top & bottom front to back.
I did make a mistake on the project though. I opened more of the the stab than needed, more work to re-glass but it allowed me to put a flox fillet on both sides of the rib. Oh...that's one more of my mistakes...I removed a part of the rib flange,,,it can be put back though.
This seems to be air my dirty laundry week lol
dmac7
PostPosted: Thu Aug 18, 2022 8:03 am    Post subject: Re: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
A few photos
 Filesize:  505.4 KB
 Viewed:  6932 Time(s)
dmac7
PostPosted: Thu Aug 18, 2022 8:05 am    Post subject: Re: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
The improved stab fit
 Filesize:  277.86 KB
 Viewed:  6927 Time(s)
peterz(at)zutrasoft.com
PostPosted: Thu Aug 18, 2022 8:27 am    Post subject: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
NICE!
I was planning on the same. What did you do for a release on the tube? I’d hate for mine to get bonded stuck lol.
Thx,
peteZ
http://forums.matronics.com/viewtopic.php?p=507703#507703
http://forums.matronics.com//files/pxl_20220818_024151257portrait2029_582.jpg
PostPosted: Thu Aug 18, 2022 8:28 am    Post subject: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
Don't forget to slot that pip pin hole in the rotational direction.
peteZ
On Aug 18, 2022, at 12:09 PM, dmac7 <dmac7(at)outlook.com> wrote:
A few photos
http://forums.matronics.com/viewtopic.php?p=507702#507702
http://forums.matronics.com//files/wp_20181216_19_24_45_pro_602.jpg
dmac7
PostPosted: Thu Aug 18, 2022 12:16 pm    Post subject: Re: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
Hi Pete,
I too was worried about epoxy sticking to the Torque tube, so I got some release wax as insurance , applied it to the tube.
The Mod plans called for some paper between the sleeves ( so BID tube is in contact only with sleeve's, not torque tube too ) then cellophane, Nev said spread some Redux on the sleeves, & wet out the BID with Redux on polythene and apply it on the tube, carefully removing polythene as required since you do 2 wraps BID.
The plans don't call for Redux but Nev said when bonding to metal it's a better choice, Aeropoxy can be just fine.
The plans available from Europa Club are well written.
dmac7
PostPosted: Thu Aug 18, 2022 3:39 pm    Post subject: Re: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
Pete, or anyone interested,
I just remembered a detail of the BID tube construction, it was done in two wraps of BID, first wrap wetted with Redux as Nev advised and he suggested the second wrap of BID to be wetted with Aeropoxy.
The Europa Club approved Mod just has one do two to three wraps all in conventional Epoxy.
PostPosted: Thu Aug 18, 2022 5:20 pm    Post subject: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
Sounds like a good idea. I will plan on wetting with redux the first ply where the bushings are. Smile
Thx!
PeteZ
http://forums.matronics.com/viewtopic.php?p=507707#507707
n7188u
PostPosted: Fri Aug 19, 2022 5:48 am    Post subject: Re: What did you do with your Europa this week 8/13 - 8/19 Reply with quote
A little late on the report but last weekend I flew south to Vero Beach with friends for breakfast and flew by the Kennedy Space Center (pictures attached). Nice flight.
This week I modified my tank vent to allow more air to get it. It's always been problematic to get fuel in from 13 gallons to full. Will test tomorrow when I fill my tank for the Saturday morning breakfast run.
Also installed quick connect fittings for the extended range tank in preparation for the Triple Tree fly-in at the end of September. Not sure I really need it since I prefer to have the luggage space but at least I will have it ready.
Chris
 Filesize:  70.39 KB
 Viewed:  6861 Time(s)
 Filesize:  69.85 KB
