What did you do with your Europa this week 7/16 - 7/22
h&jeuropa
PostPosted: Mon Jul 18, 2022 3:25 am    Post subject: What did you do with your Europa this week 7/16 - 7/22 Reply with quote
Starting the thread for this week a little late.
Jim
n7188u
PostPosted: Mon Jul 18, 2022 11:36 am    Post subject: Re: What did you do with your Europa this week 7/16 - 7/22 Reply with quote
Weather sucked last weekend but got a couple local flights on both EU and LEZ. Here are two pictures of EU taxiing and taking off by our local photographer Art Rubin.
Chris
 Filesize:  589.82 KB
 Viewed:  4166 Time(s)
 Filesize:  517.3 KB
Area-51
PostPosted: Mon Jul 18, 2022 11:01 pm    Post subject: Re: What did you do with your Europa this week 7/16 - 7/22 Reply with quote
With the PTT button failing a recent diagnostic resoldering it was time to do a better job than the original installed Radioshack button and 1970's nylon reinforced telephone receiver cord; not sufficient for safe soldering at all...
Modern technique and materials applied via CAD and 3D printer... new nipple dickers finished ready to fit... eco friendly too!! corn starch printing medium and corn starch insulation on the OEM automotive tracing; twisted pairing applied to reduce RF switching noise... PAX will now have access to transmit.
 Filesize:  159.33 KB
 Viewed:  4139 Time(s)
 Filesize:  92.51 KB
 Filesize:  92.53 KB
 Filesize:  135.35 KB
 Filesize:  144.48 KB
 Viewed:  4113 Time(s)
 Filesize:  94.18 KB
erichdtrombley(at)juno.co
PostPosted: Wed Jul 20, 2022 6:13 am    Post subject: What did you do with your Europa this week 7/16 - 7/22 Reply with quote
The wife and I flew to Big Bear Lake for breakfast in our Europa with a couple of friends in their RV-8A to escape the heat of Las Vegas, Nevada.
The flight was beautiful and smooth as glass. Big Bear (L35) is up in the mountains with a field elevation of 6,752 MSL so it was nice and cool.
The return flight was also nice albeit hot as we descended into the Las Vegas valley.
Erich
N28ET
Classic Mono 914
 Filesize:  108.38 KB
 Viewed:  4106 Time(s)
 Filesize:  93.33 KB
 Filesize:  89.04 KB
 Filesize:  39.24 KB
Area-51
PostPosted: Fri Jul 22, 2022 8:00 am    Post subject: Re: What did you do with your Europa this week 7/16 - 7/22 Reply with quote
Pushing on into uncharted territory and an ergonomic stick grip with elevator trim control; keeping things simple with 1950's cosmonaut styling...
h&jeuropa
PostPosted: Fri Jul 22, 2022 8:49 am    Post subject: Re: What did you do with your Europa this week 7/16 - 7/22 Reply with quote
Three flights this week in preparation for Oshkosh. All is well. We plan to launch for Oshkosh Sunday, time depends on weather! See you all there.
Jim & Heather
freddythek10(at)gmail.com
PostPosted: Fri Jul 22, 2022 9:09 am    Post subject: What did you do with your Europa this week 7/16 - 7/22 Reply with quote
Erich & Fred enroute
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=507521#507521
n7188u
PostPosted: Fri Jul 22, 2022 11:18 am    Post subject: Re: What did you do with your Europa this week 7/16 - 7/22 Reply with quote
Chris sitting at home working and not enroute Sad
Send pictures!!!
Chris
