The culprit
wdaniell.longport(at)gmai
PostPosted: Sat Jul 16, 2022 2:33 pm    Post subject: The culprit Reply with quote
William Daniell
+1 786 878 0246
 Filesize:  1.6 MB
 Viewed:  8205 Time(s)
freddythek10(at)gmail.com
PostPosted: Sat Jul 16, 2022 7:47 pm    Post subject: The culprit Reply with quote
Will…Can you describe the location of the crack in the tank?…F.
On Jul 16, 2022, at 3:32 PM, William Daniell <wdaniell.longport(at)gmail.com> wrote:
William Daniell
+1 786 878 0246
<PXL_20220716_164328200.jpg>
spcialeffects
PostPosted: Sun Jul 17, 2022 4:14 am    Post subject: Re: The culprit Reply with quote
And is it possible to scale the photo down to get it into a page so you can View the whole thing?
PostPosted: Sun Jul 17, 2022 4:36 am    Post subject: The culprit Reply with quote
Top "shelf" horizontal part....just to the right ot the reinforcement which was stuck pretty hard.
In other words exactly where youd expect stress.
The tank material is in pretty good shape.    However when i put in the tank many years ago i followed the manual.  It is glued in very well.....very well Sad
William Daniell
+1 786 878 0246
On Sat, Jul 16, 2022, 23:48 Fred Klein <freddythek10(at)gmail.com (freddythek10(at)gmail.com)> wrote:
--> Europa-List message posted by: Fred Klein <freddythek10(at)gmail.com (freddythek10(at)gmail.com)>
> On Jul 16, 2022, at 3:32 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
> William Daniell
> +1 786 878 0246
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
Mallard
PostPosted: Sun Jul 17, 2022 5:56 am    Post subject: The culprit Reply with quote
Will, Xmas before last I had a leak which turned out to be a fuel hose that had been sawn through by the rudder cable. During the course of asking for help here on the forum & before I found the cause, someone said that their tank developed a crack & he cut an access opening on the top big enough to get 2 hands in, to weld the crack.
Would this solution be easier for you, rather than removing the complete tank?
Cheers
James
Get Outlook for Android
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of William Daniell <wdaniell.longport(at)gmail.com>
Sent: Sunday, July 17, 2022 1:35:28 PM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: Re: The culprit
William Daniell
+1 786 878 0246
> William Daniell
> +1 786 878 0246
WIKI -
Seat of my pants
Duncan McFadyean
PostPosted: Mon Jul 18, 2022 1:17 am    Post subject: The culprit Reply with quote
James,
What did you use to "weld" the tank?
Duncan McF.
Cheers
James
Subject: Re: Europa-List: The culprit
William Daniell
+1 786 878 0246
> William Daniell
> +1 786 878 0246
WIKI -
Mallard
PostPosted: Mon Jul 18, 2022 2:13 am    Post subject: The culprit Reply with quote
Duncan,
It wasn't me who had a cracked tank. I'll have to search through the forum to find out who it was and get back to you.
James
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of D McFadyean <ami-mcfadyean(at)talktalk.net>
Sent: Monday, July 18, 2022 10:16:45 AM
James,
Duncan McF.
Cheers
James
William Daniell
+1 786 878 0246
> William Daniell
> +1 786 878 0246
WIKI -
Seat of my pants
PostPosted: Mon Jul 18, 2022 3:10 am    Post subject: The culprit Reply with quote
Everything now ripped out.  What a job.  So much for hdpe not sticking to epoxy!   The lay up delaminated rather than release the hdpe.
William Daniell
+1 786 878 0246
On Mon, Jul 18, 2022, 06:14 James <james(at)kingdom.ie (james(at)kingdom.ie)> wrote:
Duncan,
James
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> on behalf of D McFadyean <ami-mcfadyean(at)talktalk.net (ami-mcfadyean(at)talktalk.net)>
To: europa-list(at)matronics.com (europa-list(at)matronics.com) <europa-list(at)matronics.com (europa-list(at)matronics.com)>
James,
Duncan McF.
On 17 July 2022 at 14:56 James <james(at)kingdom.ie (james(at)kingdom.ie)> wrote:
Cheers
James
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> on behalf of William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)>
William Daniell
+1 786 878 0246
> William Daniell
> +1 786 878 0246
WIKI -
spcialeffects
PostPosted: Mon Jul 18, 2022 6:08 am    Post subject: Re: The culprit Reply with quote
https://m.youtube.com/watch?v=VJf1a6RhKxc
Fuel tank repair
Mallard
PostPosted: Mon Jul 18, 2022 10:24 am    Post subject: The culprit Reply with quote
Will,
The Europa owner Dave Disney gave me the following (in red) info regarding the work he did on his fuel tank.
I had to cut a hole in the top of the tank to gain access so I cut some of the material I cut out into strips to use as 'welding rods'. I used a small hot air gun to soften the tank and rods to complete the welding process. It was a bit of a pain to do and I had to develop a repair scheme for the LAA which included strengthening the area between the headrests where I cut the access hole.
In many ways I'm glad I did the repair this way. The LAA specify that I must remove the tank top panel every annual for inspection. This gives me access to inside the tank so I can check the welded area and clean out any debris from the tank. If I ever fitted a new tank, I would cut an access to it in the same way so I can inspect the tank internally.
James
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of William Daniell
Sent: 18 July 2022 12:10
William Daniell
+1 786 878 0246
Duncan,
James
James,
Duncan McF.
Cheers
James
William Daniell
+1 786 878 0246
> William Daniell
> +1 786 878 0246
WIKI -
Seat of my pants
Duncan McFadyean
PostPosted: Tue Jul 19, 2022 1:41 am    Post subject: The culprit Reply with quote
Interesting. So rather like welding a polyethylene landfill liner, which process is Environment Agency approved!
Duncan McF.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]--> On 18 July 2022 at 19:23 James <james(at)kingdom.ie> wrote:
Will,
James
William Daniell
+1 786 878 0246
Duncan,
James
James,
Duncan McF.
Cheers
James
Top "shelf" horizontal part...just to the right ot the reinforcement which was stuck pretty hard.
William Daniell
+1 786 878 0246
> William Daniell
> +1 786 878 0246
WIKI -
Duncan McFadyean
PostPosted: Tue Jul 19, 2022 1:47 am    Post subject: The culprit Reply with quote
I wonder whether the fluorination process enables a good epoxy to plastic bond? My early (non fluorinated) tank debonded from the supports at an early stage, so 'floats' about with (possibly) less stress points. Or was yours also not the later tank?
Duncan mcf
On 18 July 2022 at 12:10 William Daniell <wdaniell.longport(at)gmail.com> wrote:
William Daniell
+1 786 878 0246
Duncan,
James
James,
Duncan McF.
Cheers
James
William Daniell
+1 786 878 0246
> William Daniell
> +1 786 878 0246
WIKI -
Fred Klein
PostPosted: Tue Jul 19, 2022 5:15 pm    Post subject: The culprit Reply with quote
Can anyone confirm a date when kits with the fluorinatied tanks began to be shipped from the factory?
On Jul 19, 2022, at 2:46 AM, D McFadyean <ami-mcfadyean(at)talktalk.net (ami-mcfadyean(at)talktalk.net)> wrote:
Duncan mcf
PostPosted: Tue Jul 19, 2022 6:24 pm    Post subject: The culprit Reply with quote
My kit was bought in 2003.   Given the state of the tank i am reasonably sure that if i hadnt glued it in place there would not have been an issue.
The plastic was definitely not brittle.
Will
William Daniell
+1 786 878 0246
On Tue, Jul 19, 2022, 20:17 fklein(at)orcasonline.com (fklein(at)orcasonline.com) <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
Duncan mcf
peterz(at)zutrasoft.com
PostPosted: Wed Jul 20, 2022 12:02 am    Post subject: The culprit Reply with quote
Dunno, but my 2001 was reportedly factory fluorinated, but after i had it “redone� the surface finish was markedly different (frosted)…. So there are degrees i would assume fwiw.
PeteZ
Duncan mcf
