Charging with a maintainer
ronburnett(at)charter.net
PostPosted: Thu Jun 23, 2022 12:32 pm    Post subject: Charging with a maintainer Reply with quote
Just bought a C170. Is it possible to hook a battery maintainer to it through the cigar lighter port? It only has a 3 amp breaker
Ron Burnett
rparigoris
PostPosted: Thu Jun 23, 2022 8:26 pm    Post subject: Re: Charging with a maintainer Reply with quote
Hi Ron
Hmm, folks named Ron seem to be fool enough to purchase 170s! I owned a 1948 for 19 years.
To answer your question, if you have the time, a small charger is fine. I used a Yuasa 3 step battery charger that was 900mA. I would charge lead acid batteries from 5amps to 200 amps. I was deep cycling the 200 amp Gel Cell Decka batteries down to 60% charge. Took a while to charge, but none the less works just fine. 200 amps times .4 = 80 amps / .9 amps = 89 hours times fudge of lets say 1.3 = 116 hours. If it was below 50F, takes even longer.
Ron P.
PostPosted: Sat Jun 25, 2022 8:35 pm    Post subject: Charging with a maintainer Reply with quote
At 01:10 PM 6/23/2022, you wrote:
--> AeroElectric-List message posted by: Ron Burnett <ronburnett(at)charter.net>
Great ol' bird. Fly comfortably!
Yes, if your cigar lighter is 'always hot',
i.e. tied directly to battery via a 5A or
smaller fuse/brealer at the battery, then that
connector is the obvious choice for battery maintenance.
out of that stuff?"
skywagon185(at)gmail.com
PostPosted: Tue Jun 28, 2022 10:53 am    Post subject: Charging with a maintainer Reply with quote
Maintainers . . . Ron,
Most general purpose 12V battery maintainers are low current.  Usually under 1 amp. So, if your cig lighter is always "hot" that should work well.
Suggestion:  After the maintainer has operated for a few hours or a day, be sure to check the battery voltage at the battery.  It should be in the 13.2 to 13.5 range.
Some maintainers are in error with their final float setting voltage.
D
On Sat, Jun 25, 2022 at 9:38 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: Ron Burnett <ronburnett(at)charter.net (ronburnett(at)charter.net)>
  out of that stuff?"
PostPosted: Tue Jun 28, 2022 5:33 pm    Post subject: Charging with a maintainer Reply with quote
Bob and D,
Thanks for the info. Sadly, right now at least, It is wired on the main bus that requires the switch to be on.
Since this is a certified plane, can I add a hot buss on the forward firewall for the maintainer and the clock? Legally? If so, how would it be recommended?
Ron Burnett
May you have the Lord's blessings today!Sent from my iPad
On Jun 28, 2022, at 1:54 PM, skywagon185guy <skywagon185(at)gmail.com> wrote:
D
out of that stuff?"
PostPosted: Tue Jun 28, 2022 6:01 pm    Post subject: Charging with a maintainer Reply with quote
At 08:32 PM 6/28/2022, you wrote:
Bob and D,
You have an electric clock? Then is there a fuse
holder mounted on a bracket next to the battery
contactor? Where is your battery located . . . on
firewall or behind cabin?
out of that stuff?"
PostPosted: Tue Jun 28, 2022 6:08 pm    Post subject: Charging with a maintainer Reply with quote
There is a tube fuse for the clock hanging by the battery which is mounted pax side firewall forward.
On Jun 28, 2022, at 9:02 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Bob and D,
out of that stuff?"
