What did you do with your Europa this week 5/23 - 5/30
h&jeuropa
PostPosted: Mon May 23, 2022 2:58 pm    Post subject: What did you do with your Europa this week 5/23 - 5/30 Reply with quote
Starting thread for this week.
We are finally making progress on our Condition Inspection. Yea!!
Jim
budyerly@msn.com
PostPosted: Thu May 26, 2022 1:50 pm    Post subject: Re: What did you do with your Europa this week 5/23 - 5/30 Reply with quote
N12AY got some new toys tested.
1. GRT latest updates to my Mini.
2. Stall warning system (my own) calibrated and works great.
3. Pulled the stall strips as the landing speed was 3 knots higher and I know I can do better. Nice burble though.
4. Swapped out an EGT probe again then checked them both with a torch. EGTs read dead even now. (Only been a year!)
5. New upgrade to my Stratux ADS-B in. Seems to be fine mounted now in the back behind the bulkhead.
6. New LED light for my sight gauge replaced the incandescent test rig.
7. Fuel flow transmitters need to be checked.
I'll fly it again to verify all the above on the next ops flight.
I have an upper respiratory sinus block that is finally healing with the medication and Anita has let her's go on too long and now has pneumonia. We both got RSV (an Infant Respiratory Virus) from our new grandson. It was worth it. We are both doing just fine as is our grandson. Coughing and hacking helps you loose weight I hear.
