406 ELT
arcticarrow(at)gmail.com
PostPosted: Sat Apr 16, 2022 9:48 am    Post subject: 406 ELT Reply with quote
I’m considering a horizontal installation of a 406 ELT antenna because if really in need of rescue the plane would most likely be on its nose or upside down making the typical vertical installation non functional or limited. On a tube and fabric aircraft what would be an effective sized ground plane?
Bernie
PostPosted: Sat Apr 16, 2022 2:01 pm    Post subject: Re: 406 ELT Reply with quote
The radius of the ground plane should be equal to the length of the antenna.
Joe Gores
PostPosted: Sat Apr 16, 2022 5:18 pm    Post subject: 406 ELT Reply with quote
Joe
Thank you
Bernie
Joe Gores
http://forums.matronics.com/viewtopic.php?p=506564#506564
