Flying with full down trim
peterz(at)zutrasoft.com
PostPosted: Wed Mar 30, 2022 9:02 am    Post subject: Flying with full down trim Reply with quote
So after reading that very strange European accident report which attributed cause to the full down trim and stick forces, i decided to give it a try.
Conclusion: balderdash.
My classic has a typical slight rear of center CG, trim indicator calibrated to read center when the trim is in line with the fuse-tailplane-moulding, and typically take off with 2.5 lines down trim on the indicator.
I flew 1.2hrs, including 2 circuits, from startup to shutdown at full down trim without issue. Sure the feel/pressure is off, but nothing of major concern. Surely not anything “startling”.
Sure, every plane flys differently, but i still cannot understand that report’s conclusions. Fuel starvation on a steep climb-out appears to me to be the more reasonable conclusion.
FWIW YMMV etc.
PeteZ
C-GNPZ
stranfaer(at)btinternet.c
PostPosted: Wed Mar 30, 2022 9:38 am    Post subject: Flying with full down trim Reply with quote
Did you also try the other way eg full up?
Sent from David’s iPhone
FWIW YMMV etc.
PeteZ
C-GNPZ
christoph.both(at)acadiau
PostPosted: Wed Mar 30, 2022 10:26 am    Post subject: Flying with full down trim Reply with quote
Pete,
Did you try trim all the way up?
Christoph
On 2022-03-30, 2:02 PM, "owner-europa-list-server(at)matronics.com on behalf of Pete" <owner-europa-list-server(at)matronics.com on behalf of peterz(at)zutrasoft.com> wrote:
CAUTION: This email comes from outside Acadia. Verify the sender and use caution with any requests, links or attachments.
FWIW YMMV etc.
PeteZ
C-GNPZ
dmac7
PostPosted: Wed Mar 30, 2022 10:56 am    Post subject: Re: Flying with full down trim Reply with quote
Pete thanks for testing this config, good to know. I think of the Swiss cheese model of accident factor's, the report said take-off was attempted with nearly empty fuel tank ( 6.5 liters or less in main ), on a day with winds 15kt gusting 23kt not a good day for a steep climb out, and pilots habit of steep climbs, the trim situation may or may not have been different than previous flights. They didn't address the likelihood of fuel starvation at the steep pitch angle with low fuel in the tank. We can only try to learn from this, mistakes... we all make em. Keeping a little distance from the edge of the performance envelope seems a good idea.
Area-51
PostPosted: Thu Mar 31, 2022 1:27 am    Post subject: Re: Flying with full down trim Reply with quote
So just to clarify this Pete; was it the trim indicator on the instrument panel that you set at the full down position? My aircraft flies fine with full down trim selected though its not very comfortable on departure or approach and requires a higher pilot work load. With 2 bars down trim selected my observations show the aircraft wanting to pitch up on departure as speed increases; again uncomfortable flying if trim is not adjusted down further.
Interesting point made regarding departure attitude and possible fuel starvation. Many factors, haven't read the incident report; was aux fuel pump on? Why did the pilot elect to take off with such a low fuel reserve? Was reserve position selected at the fuel valve?
PostPosted: Thu Mar 31, 2022 3:16 am    Post subject: Flying with full down trim Reply with quote
Correct, and my trim motor was also at its down limit…..and consistent with my findings.
PeteZ
On Mar 31, 2022, at 5:43 AM, Area-51 <goldsteinindustrial(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=506452#506452
Area-51
PostPosted: Thu Mar 31, 2022 1:12 pm    Post subject: Re: Flying with full down trim Reply with quote
Thanks... how did you find the aircraft handled in circuit on downwind and final with the trim set as you had? Did you find it a situation that was challenging or easily physically mitigated?
PostPosted: Thu Mar 31, 2022 1:38 pm    Post subject: Flying with full down trim Reply with quote
everybody and aircraft are different, but simple bit of pressure and nothing special. Of course daydreaming isn't allowed (and never should be Wink )
The flare is obviously odd....if one is used to being trimmed out on final.
PeteZ
On Thu, Mar 31, 2022 at 4:19 PM Area-51 <goldsteinindustrial(at)gmail.com (goldsteinindustrial(at)gmail.com)> wrote:
--> Europa-List message posted by: "Area-51" <goldsteinindustrial(at)gmail.com (goldsteinindustrial(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=506461#506461
WIKI -
