What did you do with you EUROPA
alan.twigg775(at)gmail.co
PostPosted: Tue Mar 22, 2022 9:11 am    Post subject: What did you do with you EUROPA Reply with quote
Finally got most of my sensors to talk to the new Kanardia Daqu/Digi. Great improvement from my old generation Flydat and it is in my eye-line. 30 minutes flying plus soaring up 500 ft, Winter vario also works.
Roll on Summer soaring.
Alan Twigg
Motorglider Wings G-GIWT
Kit 463.
peterz(at)zutrasoft.com
PostPosted: Tue Mar 22, 2022 9:29 am    Post subject: What did you do with you EUROPA Reply with quote
awesome!
Please keep the soaring pireps coming! Inspiration for us long wing builders.
Still  chasing down my intermittent resonance.
Question for folks: what typical pull values are folks seeing for their gearbox dog friction measurement? I'm near the low limit of 22ft-lbs.
Pete
On Tue., Mar. 22, 2022, 1:19 p.m. Alan Twigg, <alan.twigg775(at)gmail.com (alan.twigg775(at)gmail.com)> wrote:
--> Europa-List message posted by: Alan Twigg <alan.twigg775(at)gmail.com (alan.twigg775(at)gmail.com)>
Alan Twigg
Kit 463.
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
rparigoris
PostPosted: Tue Mar 22, 2022 2:15 pm    Post subject: Re: What did you do with you EUROPA Reply with quote
Hi Pete On our 914 circa 2005 which is new and only run at factory, I pulled the gearbox to inspect things and purged oil system and got oil pressure. Engine was at room temp with Mobil 1 10w30 oil. It also has a B&C SD20S alternator on the vacuum pad which definitely adds to friction. I measured January 284.4 inch lbs., or 17.8 foot lbs.
Maximum allowable friction is 1,328 inch lbs., or 83 foot lbs., so I was just about 22% allowable. Ron P.
PostPosted: Tue Mar 22, 2022 2:45 pm    Post subject: What did you do with you EUROPA Reply with quote
My bad I wasn't clear enough.... I was speaking of the locked-crankshaft dog-clutch friction test as per the pic of the Line maintenance manual attached.
I am very near the minimum torque spec (22-51.6ft-lbs), with a freshly serviced (by the local authorized rotax center) box.... discouraging.
I was wondering what other folks are seeing typically.... ie - near the bottom as well? Or nicely centered in the range (and (at) how many hours).
Cheers and thanks!
PeteZ
C-GNPZ
912ULS
[img]cid:ii_l12q319e0[/img]
On Tue, Mar 22, 2022 at 5:23 PM rparigoris <rparigor(at)hotmail.com (rparigor(at)hotmail.com)> wrote:
--> Europa-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=506370#506370
WIKI -
 Filesize:  142.77 KB
 Viewed:  3103 Time(s)
h&jeuropa
PostPosted: Thu Mar 24, 2022 5:04 am    Post subject: Re: What did you do with you EUROPA Reply with quote
Pete,
I looked at the last couple years of inspections and found that our 914 shows about 35 ft lbs. We measure with a cheap fish scale so accuracy is not real high but reasonable.
Jim & Heather
