Eric Page
Posted: Tue Feb 22, 2022 9:35 pm Post subject: Sizing a B-lead ANL |
I'm asking for a friend, who is installing a Verner radial engine on a Kitfox...
In some of the Z-figures, ANL current limiters are annotated as "sized to alternator." In others, the annotation refers to Note 10, which doesn't discuss sizing. On Z-12, the alternator is labeled as 60A, and the ANL is annotated as "ANL60."
So, should the ANL rating match the alternator nameplate rating as closely as possible, or slightly exceed it, or is there some other formula? I didn't find anything specific in the text of the 'Connection, and a search on the forum came up empty as well.
Eric
Eric Page
Posted: Wed Feb 23, 2022 9:03 am Post subject: Re: Sizing a B-lead ANL |
Thanks very much, Joe. I'll pass that along.
Eric
johnbright
Joined: 14 Dec 2011 Posts: 167 Location: Newport News, VA
Posted: Wed Feb 23, 2022 11:16 am Post subject: Re: Sizing a B-lead ANL |
I haven't been able to find a definition or history of current limiters, but, at least in the case of ANL current limiters of the ratings we use, it seems like they are designed so you don't have to calculate how much bigger than the load to size them, just use one placarded for your load. Note a 60A ANL will carry over 100A continuously.
Here's what I put on my schematic:
Littlefuse MIDI/Bussmann AMI fuses are specified on this schematic for the alternator B leads versus legacy ANL current limiters because they are physically smaller.
ANL current limiters with the same rating as the alternator could be used but MIDI fuses of a higher rating are chosen. It is assumed the alternator is capable of 120% of its rated output, this is divided first by 0.75 (nuisance blowing factor per Littelfuse "Fuseology" document) and then by 0.95 (temperature re-rating factor per Littelfuse MIDI data sheet, 170F firewall temperature is assumed).
Main alternator: (60 * 1.2) / (0.75 * 0.95) = 101 A, close enough to 100 to choose a 100 A MIDI.
Vacuum pad alternator: (35 * 1.2) / (0.75 * 0.95) = 59 A, a 60 A MIDI is chosen.
Alternate for alternator B leads is FLW (fuse link wire) 6" long, 4 awg smaller than B lead, PICO brand is common; available from 10 to 20 awg. FLW is a slightly cleaner installation; ANLs, and especially MIDIs, open with less energy.
_________________ John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links |
Posted: Wed Feb 23, 2022 11:35 am Post subject: Sizing a B-lead ANL |
At 11:35 PM 2/22/2022, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Eric Page" <edpav8r(at)yahoo.com>
ANL devices are EXCEEDINGLY robust
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
An ANL60 will carry over 100A continuously.
This tells us that current limiters are designed
to mitigate HARD faults (many hundreds of Amps).
So picking an ANL equal to or even SMALLER than
the alternator is not a sketchy idea.
Alternatively, consider a fusible link (4AWG
smaller than B-lead). This will serve the same
purpose and is often less expensive and more
installer-friendly.
As the Z-figures evolve, ANL and similar
devices are going to be replaced with fusible
links.
out of that stuff?"
Posted: Wed Feb 23, 2022 11:37 am Post subject: Sizing a B-lead ANL |
At 01:16 PM 2/23/2022, you wrote:
| Quote: | --> AeroElectric-List message posted by: "johnbright" <john_s_bright(at)yahoo.com>
Alternate for alternator B leads is FLW (fuse link wire) 6" long, 4 awg smaller than B lead, PICO brand is common; available from 10 to 20 awg. FLW is a slightly cleaner installation; ANLs, and especially MIDIs, open with less energy. |
Exactly. But life is much simpler with fusible links.
out of that stuff?"
Ceengland
Posted: Wed Feb 23, 2022 1:43 pm Post subject: Sizing a B-lead ANL |
snipped
installer-friendly.
links.
| That's what I did. I confess to using a pair of off-the-shelf Denso internally regulated alternators, with the OV protection on a pair of continuous duty contactors on the firewall. The blue wires in the pic are actually 12awg fusible link wire, doing double duty as interconnects and protection for the 8awg B leads (~2 foot runs).
Needless to say, I'm a big fan of using links.
Charlie
220.75 KB |
7774 Time(s) |
_________________ Charlie |
Posted: Wed Feb 23, 2022 7:48 pm Post subject: Sizing a B-lead ANL |
| Quote: | That's what I did. I confess to using a pair of off-the-shelf Denso internally regulated alternators, with the OV protection on a pair of continuous duty contactors on the firewall. The blue wires in the pic are actually 12awg fusible link wire, doing double duty as interconnects and protection for the 8awg B leads (~2 foot runs).
Needless to say, I'm a big fan of using links. |
me too . . .
The probability of a hard-fault to a b-lead is exceedingly
low . . . but FMEA protocols do not consider 'exceedingly
low' . . . they ASSUME that if a failure is at all possible, then
design mitigation into the system.
This is how mission-reliability is promoted . . . mission
critical features of the airplane are first rendered
non-hazardous and then backed up by a system unlikely
to be affect by the same stresses while you finish consuming
one tank full of fuel. Hence, NO SYSTEM is really mission-
critical irrespective of the MTBF numbers.
ANL and similar devices are parts, installation and cost
intensive while adding an incalculably small if not
zero value to system reliability. So a piece of 'magic
wire' with a terminal on one end and splice on the other
seems quite practical.
out of that stuff?"
Eric Page
Posted: Thu Feb 24, 2022 11:49 am Post subject: Re: Sizing a B-lead ANL |
Thanks, everyone. I've given my friend a link to this thread so he can absorb the hive's wisdom directly.
One other question he asked me is whether or not to carry a spare for whatever B-lead protection he chooses, whether it's ANL, Maxi or fusible link. Thoughts, pro or con?
Posted: Thu Feb 24, 2022 12:56 pm Post subject: Sizing a B-lead ANL |
One other question he asked me is whether or not to carry a spare for whatever B-lead protection he chooses, whether it's ANL, Maxi or fusible link. Thoughts, pro or con? |
If you've popped a b-lead protector . . . having a spare
is the least of your worries. If this protection ever
opens, there's a SERIOUS issue to be addressed.
In fact, if he is using fuseblocks as opposed to
breakers, council him on temptations to fiddle
with ANY fuse or breaker in flight. . .
See: http://aeroelectric.com/articles/fusvsbkr.html
out of that stuff?"
