ground power deep discharge of battery
PostPosted: Thu Feb 10, 2022 10:10 am    Post subject: ground power deep discharge of battery Reply with quote
If the polarity is backwards, the diode that is across the contactor coil will conduct a large current and blow the fuse that you are going to install.
Hopefully that will happen quick enough to prevent damage to expensive avionics.
Nothing 'hopeful' about it. The diode, being FORWARD
biased, will not have a voltage drop not exceeding
1 volt or so while the fuse is in the process of
melting it's brains out . . . a couple milliseconds.
The voltage impressed on the contactor coil during
this interval is too short and too low for the
contactor to even think about closing.
out of that stuff?"
