SURFACE MOUNTED THROUGH HOLE COMPONENTS
PostPosted: Mon Jan 31, 2022 10:11 am    Post subject: SURFACE MOUNTED THROUGH HOLE COMPONENTS Reply with quote
I made a circuit on perf board with all components and wires on the top surface so that the perf board can be be fastened directly
to aluminum without shorting out. I glued the components to the board with E6000.
When completed, I coated everything with a layer of E6000. That keeps wires apart that are not supposed to touch.
The value of R1 determines setpoint. You might want to use a POT. The light comes on at about 13.2 volts.
Choose the value of the LED resistor based on the voltage drop of your LED.
I don't need this warning light because my EFIS warns if the voltage is low.
It was a fun winter project.
 Filesize:  14.11 KB
 Viewed:  2806 Time(s)
Components are glued to board with E6000
 Filesize:  24.92 KB
Wires that cross are spaced vertically
 Filesize:  21.7 KB
Everything potted with a layer of E6000
 Filesize:  20.38 KB
Joe Gores
John M Tipton
PostPosted: Tue Mar 08, 2022 2:03 am    Post subject: Re: SURFACE MOUNTED THROUGH HOLE COMPONENTS Reply with quote
And: for a filament bulb, just remove the resister: yes !!!
